Old 04-24-2017, 07:55 AM   #1
Question Hot water tank question
New to owning a travel trailer,and unsure about whether or not we should empty hot water tank while travelling.
Bob and Diane
Grandm2015 is offline   Reply With Quote
Old 04-24-2017, 08:13 AM   #2
If you camp often, like we do, fill it up in the spring and drain it in the fall. Other than that it's your choice. No need to drain it while traveling.
Les & Heidi Kramer
2021 Jayco Melbourne 24L
Olmsted Township, OH
cpd1343 is offline   Reply With Quote
Old 04-24-2017, 08:21 AM   #3
SeaDog's Avatar
X2 what CPD said
Retired Navy
2016 Flagstaff 26 FKWS
Old 04-24-2017, 12:43 PM   #4
Mr. Dan's Avatar
Yep... I fill mine in March and drain it in mid-November. Some drain the heater after every trip but their water may not be as free of barnacles as mine.
Old 04-24-2017, 10:43 PM   #5
I drain the tank between trips. It only take a couple of minutes as I have a thumb twist drain valve on my hot water heater. As for travelling, keep it full.
Skyliner is offline   Reply With Quote
Old 04-25-2017, 09:40 AM   #6
I shed all the extra weight I can. If I was camping without hookups I would probably leave it alone but any weight I can shed, I will.
mj0528 is offline   Reply With Quote
Old 04-25-2017, 08:33 PM   #7
I leave my hot water heater full along with 20 gallons in the fresh water tank
spock123 is offline   Reply With Quote
Old 04-25-2017, 08:41 PM   #8
crunchman12001's Avatar
The water in your water heater tank will be fine while traveling but if you do not plan to use it for a couple weeks, make sure to drain it. The water will get funky after a couple weeks.
2015 F-250 FX4
hot water, tank, water, water tank
