Old 06-02-2013, 09:45 AM   #1
Hot water temp. adjustment
I fell horrible about asking this question cause it's probably so simple but we just bought our first travel trailer, a 26TBUD. Is there anyway to adjust the temperature of the hot water heater and if so where is it located at. I can't find it on the heater anywhere. Maybe just over looking it or it looks nothing like what i'm used to seeing.
jrsellers67 is offline   Reply With Quote
Old 06-02-2013, 09:48 AM   #2
Alleged curmudgeon
Vern's Avatar
Don't feel bad. I'm a little over a year ahead of you and have not even thought of the question. I have always just assumed that, unlike our home hot water heaters, there simply is no adjustment. I'm sure someone will let us know here quickly.
Should add that I presume we are both probably equipped with the common 6-gallon Suburban brand water heater.
Lee
2013 Windjammer 3008W
2006 Chevy Silverado 2500HD 6.0L w/Equalizer 4
Nights camped: 2012 (29); 2013 (26); 2014 (40); 2015 (43); 2016 (35); 2017 (34); 2018 (39); 2019 (22)
Vern is offline   Reply With Quote
Old 06-02-2013, 10:08 AM   #3
There may become older units with adjustable thermostats, but most of the new ones are fixed at 120*
2011 A-122
rawlus is offline   Reply With Quote
Old 06-02-2013, 10:11 AM   #4
VinceU's Avatar
Actually you can, under the outside panel there is a square cover over the 12V thermostat and 110V thermostat. Its changed as a unit whichever you want to modify. They are marked 120-150 and you can buy them from Suburban- the only way. I did it.
Old 06-02-2013, 10:32 AM   #5
Alright it sounds like I'll be in touch with Suburban and get a new thermostat. Thanks for everyones input, gotta love this forum.
Old 06-02-2013, 10:51 AM   #6
troyt's Avatar
From what I understand the temp is factory set at 140° (typical). However, there are aftermarket kits you can get depending on the model you have.
Sample adjustable controller.
Replacement Thermostat for Suburban SW-Series Water Heaters, Gas Control
or use a mixing valve.
0215473 - Watts 0215473 - 1/2" L70A-T Lo-Temp Threaded Tempering Valve (100°-130°) on the outlet of the water heater. Pretty easy to hook up, it just mixes hot and cold water to the adjusted temp. Extends the hot water supply and gives a more even temp output.
I'm sure others will chime in that are more knowledgeable.
2017 Dodge 2500 Crew Cab 6.7L Cummins 4X4 38k mls
2010 Forest River Flagstaff 831QBSS - Equal-i-zer Hitch
2011 HD FatboyLo & 2000 Honda Shadow 1100
Nights Camped 2010 (7), 2011 (15), 2012 (35) 2013 (40) 2014 (22) 2015 (12) 2016 (10) 2017 (10) 2018 (10)
troyt is offline   Reply With Quote
Old 06-02-2013, 12:26 PM   #7
VinceU's Avatar
Wow for these numbers you are half way to a new heater. Just call Dometic, about 25 bucks, your choice.
