Old 06-03-2017, 10:43 AM   #1
campsmith1's Avatar
Hours from PDI
Morning to all, just a couple of hours before PDI on our new Wildwood X lite 261 Bhxl! Any advice would be great.
campsmith1 is offline   Reply With Quote
Old 06-03-2017, 11:13 AM   #2
SeaDog's Avatar
Do not let them rush you, make sure everything is actually checked example is the microwave bring some popcorn along to test it don't assume it works because the lights are on. Test the water heater on both gas and elect same with the frig. Plan 3 to 4 hours for a really go check. The time you take will pay off in the end.
Retired Navy
Jake my sidekick (yellow Lab)
2016 Flagstaff 26 FKWS
Old 06-03-2017, 11:39 AM   #3
DaGrinch's Avatar
Yeah, what he ^^^^^ said!
Check and make sure all faucets work, the furnace kicks on as well as the a/c, open and close all the slides (if any). Open and close all storage areas as well as work the locks, open and close all drawers and cabinets/wardrobes. Turn on/off all the lights, light the stove and oven (probably the only time oven will be lit) and make sure there are no propane leaks. Show how to use the TV and any dvd players, as well as the difference between the over-the-air antenna and the satellite feature.
Have them show you the converter and go in detail the difference between the 12v side and the 110v side - how to tell "quickly" if you blow a fuse or if a circuit breaker trips.
They should show you exactly how to hook up any tanks to be emptied and have them demonstrate the black tank flush.
These are just a few if what I consider the major issues most people will run across.
HERE is a PDI Checklist you can download. One other suggestion is to take a video (camera/cellphone) of the PDI.
Ultimately,
"Sunny" the 2017 Sunseeker 3010DS
2006 Jeep Liberty Toad
.... and lovin' life........MOST of the time.
DaGrinch is offline   Reply With Quote
Old 06-03-2017, 04:43 PM   #4
RETIRED
n-e-d's Avatar
TAKE YOUR TIME. Key words to remeber"show me"
Mary and Me
2015 2650s "Finally"
2015 Jeep Cherokee
2016 Ford Race Car Red 350HD Cargo Van HR DRW EXT DIY Daytripper "Red Roamer"
n-e-d is offline   Reply With Quote
Old 06-03-2017, 04:46 PM   #5
RETIRED
n-e-d's Avatar
Whoops just noticed the time stamp..so how'd it go?
Mary and Me
2015 Jeep Cherokee
Old 06-03-2017, 11:28 PM   #6
campsmith1's Avatar
Just wanted to say thanks. It went great! Dealer went over everything pretty well. Only thing I didn't get into was the remotes my fault there. I Said I could figure them out with no problems. I might have been wrong there but will do some reading.
Thanks again
pdi
