Old 04-04-2015, 02:04 PM   #1
greti's Avatar
How do I remove the strap holding the battery case?
I feel a little stupid asking this question but I can not get the strap off the battery case which is housing the battery. I need to get the battery out to charge it. The nylon strap and buckle are on tight and I have tried and tried to loosen them. Is there some trick to this I'm not aware of? Click image for larger version
Name:	ImageUploadedByForest River Forums1428174162.125898.jpg
Tennessee
2014 Rockwood Mini Lite 2504s
2006 Ford Expedition
greti is offline   Reply With Quote
Old 04-04-2015, 02:10 PM   #2
Try wedging a screwdriver under the top of the bottom strap. That may loosen it up enough.
whitmw is offline   Reply With Quote
Old 04-07-2015, 12:11 PM   #3
Christian_D's Avatar
Originally Posted by greti View Post
I feel a little stupid asking this question but I can not get the strap off the battery case which is housing the battery. I need to get the battery out to charge it. The nylon strap and buckle are on tight and I have tried and tried to loosen them. Is there some trick to this I'm not aware of? Attachment 73049
Does the buckle part consist of two pieces sandwiched together? If so, then they slide apart......one piece pushes forward and the other pushes back.....then they'll separate to give you the room you need to loosen the strap.
Hope that makes sense...
Christian
Reno, NV
2015 Georgetown 270
Days Camped 2015: 40
Days Camped 2016: 03
Christian_D is offline   Reply With Quote
Old 04-07-2015, 12:24 PM   #4
Stormrider151's Avatar
In the picture it looks like you may have tried this but, with a screw driver try to slip in under the end that feeds back through the buckle and work it out. Then pull up on the bottom side of the buckle to relieve the pressure from the jaws of the buckle. This is tough to explain and those straps can be a real pain sometimes. And the only dumb question is the one that isn't ask :-)
Retired Fire Dept Battalion Chief
2016 Ever-Lite 232RBS
2012 F150 FX4 W/Max tow & Ecoboost
Getting old ain't for wimps!!!
Stormrider151 is offline   Reply With Quote
Old 04-07-2015, 12:53 PM   #5
lickem66's Avatar
Mine was a PITA too so once I got tired of fighting with it, I replaced the buckles with a snap on type one in the link below. I found them at Ace Hardware, I believe.
http://www.iboats.com/mall/image/vie...ose_4812_2.jpg
2016 FR3 28DS
Past 2012 Forest River Rockwood 2104.
2016 Nights Camped = 34, 2015 = 21, 2014 = 22, 2013 = 24
lickem66 is offline   Reply With Quote
Old 04-07-2015, 06:09 PM   #6
greti's Avatar
Thank you for the feedback. I tried using scissors to pry the straps loose but the teeth on the buckles have made this nearly impossible. I did wonder if I needed to slide the buckle apart but I didn't have adequate strength to do this either. I am close to cutting this thing off and replacing it with the type noted by lickem66. It really should not be so hard!lol
Tennessee
Old 04-07-2015, 07:08 PM   #7
Traveling along
Bill and Margo's Avatar
We cut ours off and replaced with a heavy chain and strong padlock.
Bill and Margo
2014 Silverado 1500
2014 Tracer Air 235
Bill and Margo is offline   Reply With Quote
Old 04-07-2015, 07:12 PM   #8
A sharp knife will eliminate your frustration and is quick! (Use the knife on the strap only)
Old 04-07-2015, 07:25 PM   #9
crunchman12001's Avatar
If you plug your camper in to an outlet, the battery will charge. There is no need to remove the battery unless for replacement or storage. If you do not have access to an outlet, cut the strap and buy a new one.
crunchman
2015 F-250 FX4
Old 04-07-2015, 07:27 PM   #10
Dodge Guy's Avatar
It looks like someone looped the strap back into the buckle. You'll need to pull the strap back out the top then twist the buckle up and this will disengage the teeth. 8 years later and mine is still hard to release!
02 Ford Excursion V-10 4.30 gears 5 Star Tuner Y-pipe mod Hellwig sway bar Rear Airbags
Prodigy and Dual Cam
07 Cherokee 32B
Better to have a bad day of camping than a good day at work!
Dodge Guy is offline   Reply With Quote
battery
