Old 10-07-2016, 06:51 PM   #11
Originally Posted by larryo View Post
My valves are right at the tank
I thought they were all like that. Sorry, I can't help.
I took a length of PVC pipe and put a coupling on the end. I then cut a notch on the coupling to fit over wing on valve. Reaches and works great
newcowg is offline   Reply With Quote
Old 10-07-2016, 07:46 PM   #12
Brilliant! Thanks!
Pam & John in WI
PamJohnZephyr is offline   Reply With Quote
Old 12-03-2016, 08:24 PM   #13
Left Coast
Did the same thing to open roof vent
Retired....but work part time as a pain in the north end of a south bound donkey.......2010 Rockwood 8280 5er....99 Dodge 2500 turbo Cummins
Old 12-04-2016, 09:12 AM   #14
Originally Posted by D W View Post
You are correct. In this two valve configuration the white valve is a re-direct to route the supply cold water through the TT hot water lines, and the black valve prevents that flow from entering the hot water heater. If you are winterizing make sure the first thing you do is drain the hot water heater. If your TT is equipped with a Suburban water heater leave the anode rod, which is attached to the 1 1/16" drain plug, out during winter storage. Plug the drain hole with a 3/4" PVC pipe plug available from Home Depot or Lowes. This is a good time to inspect the anode for severe deterioration. Minor pitting of the rod is normal, but when big chunks of the rod are missing it may be time to get a new one. They're not that expensive. If the rod is satisfactory, dry it thoroughly, place in a plastic bag and tuck it inside the water heater door so as not to forget it when you de-winterize in the spring.
Why would it be necessary to store the anode rod outside of the unit? Thanx.
glory rcing is offline   Reply With Quote
Old 12-04-2016, 10:23 AM   #15
It isn't. I either reinstall the old one (if there is still life left) or install a new one after draining and flushing. On less step in the spring. It is just sticking into thin air inside the tank once drained and flushed. No harm to it whatsoever.
2016 Flagstaff 8529IKBS Diamond Package 5th Wheel
Ford F-Series SCREW 4x4
TST Tire Monitor - Sinemate 3500w Gen.
2016 Nights Camped = 46
Old 12-04-2016, 11:19 AM   #16
That is good to hear as I replaced my anode this year when winterizing. I simply drained/cleaned tank and installed new anode with Teflon tape. Ready to go when the weather finally cooperates!
Thanx for replying.
