09-08-2010, 01:12 PM
volunteer moderator
How do you "winterize" a honda eu2000
IMO Honda dropped the ball on this generator.
There is no easy way to drain the gas tank OR any
way to totally drain the carb. (Correction- I now know
there is a carb drain screw but no tank drain.)
I want all the gas out of there!!
Does anyone have any suggestions or helpful youtube links
showing how to totally drain one??
Yeah, I can siphon the tank as empty as possible and
then run it until it quits. That will still leave a teaspoon
in the carb that will eventually evaporate and leave some
gas gum behind
How do you handle your genny during the long off season?
Peace!
Dan & Rita D
2008 Rockwood 2502 Ultra Lite
2004 5.3L Silverado 1500 ext. cab 2WD
Reese dual cam hitch, AirLift load levelers
53 days camping in 2010, 47 days in 2011
09-08-2010, 01:16 PM
This is common for many gas powered engines Dan. It's why I use Stabil in all our stuff, the gas that is left behind will be treated and won't go bad over the several months of storage. Like other things like outboard motors, ATVs, Snomobiles etc you can use a fogging spray too to help. Personally I just leave the Stabil treated gas in my portable generators and go out and start them once a month.
We usually get enough power outages around our place to keep them in use anyway. Heck if moth in India farts we loose our power.
09-08-2010, 02:05 PM
volunteer moderator
I'm on the fence whether to stabil it or run it as dry as possible.
Problem is I have a whole house genny so the honda is not needed
except as a loaner to neighbors or for camping.
In fact, we took it on our month long trip in June and only started
it twice so my wife could use the microwave. She said she could
get by without it but we'd hauled it 4000 miles and by golly we were gonna
use it!
It won't quite start the compressor on my roof AC
We have twin 12v batteries and had no problem going a week
dry camping so didn't need it for charging either.
Every other stop had electric so low batteries were not an
issue.
It's a very expensive "insurance" policy as of now.
BTW my big genny is a 5.5 Kw brigs powered monster that
does have a carb drain screw.
I used to leave stabil treated gas in it but it's been a year since
the last extended power outage so I recently drained it into a gas can,
poured that into my car and used it up. Drained the carb and
always have at least 5 or more gallons in the garage. With
leaf removal, fall mowing, winter limb chopping etc, the gas cans
in the garage don't have a chance to go stale.
In an emergency I could siphon from my truck which is typically
full and under a cover in the garage.
Honda should have put a drain in their carb!!!
Peace!
Dan & Rita D
09-08-2010, 04:04 PM
my portable circa 96 honda generator
gets stabil in the fuel and i shut off the fuel to the carb and let it run until it quits.
then my carb bowl drops off with one nut and i drain it and clean it out and re-install.
my tank is great , it has a drain , but i never drain it.
like many others mine doesn't normally stay dormant for more than a few weeks,
i use it often.
Living in the Piney Woods of Texas.
09-10-2010, 10:15 PM
Dan,
Click here and scroll down to page 50 & 51.
It shows a Carburetor Drain Screw.
09-28-2010, 08:53 PM
Use Stabil. It works. I use on all my gas powered equipment and a pontoon boat. I used to run the tanks dry but that is such a pain and a waste of gas.
kz08h5
2008 Chevy Silverado 2500 Duramax Crewcab
Jeep Commander - sold
Flagstaff V-Lite WRB26
09-28-2010, 11:05 PM
Moderator
Stabil works, High Test gasoline is cheaper. I use high test in the mowers and weed eaters, chainsaws, etc, and never have a problem. That may sit for several months. I am a mechanic, ASE certified Master Tech, but your mileage may vary.
Windrider,
Too many toys, not enough time.
2001 F150 SuperCrew
2002 Jeep Wrangler
1978 Cessna 152
2000 Honda 750 Nighthawk
2008 Work and Play 18LT
09-29-2010, 12:28 PM
Dave, Judy & Dazey
For the better part of the last 15 years I’ve kept three 5 gal gas cans in the garage. When I fill them I add the Stabil right away.
I then use the gas to fill all my toys as needed ie Quad, 9.9 hp outboard, John Deere riding mover, chain saw, weed whacker, Honda EU3000, Sears powerwasher, leaf blower.
When it’s off season for anything I top off the gas/oil so there's no air space, remove batteries if equipped & the unit sits.
Have never had anything that didn’t start when needed next.
I keep up with maintenance as outlined in each of the owner’s manuals.
11-22-2010, 08:16 AM
volunteer moderator
Follow up--
Thanks to Milzat for pointing out that I should have read my owners
manual. (I'm a guy and I hate reading directions!)
Turns out my honda genny has a carb drain screw with a built on
carb drain hose. No drain on the tank tho.... ya gotta siphon the
tank if you want it empty.
I also discovered it has a fuel pump! The owners manual
referenced above gives several steps to short, medium and long
term storage. Very good reading.
I siphoned the tank, ran it until it quit and then drained the carb.
I put it away under a dust cover. 3 weeks later we took a "last
trip of the season" and on a whim, I took it "just in case".
We visited Cumberland Gap National Park for 4 days.
No reservations allowed.
The electric sites were mostly full and the non-electric were
mostly empty. We grabbed a nice flat, secluded non-electric.
We watched TV every night using a little cigarette socket inverter
and used the LP furnace to keep the temps above 50 while
we were in bed and closer to 65 during breakfast and supper.
I ran the honda for 2 hours during breakfast on the 3rd morning
to top up the batteries.
It was an awesome trip made all the better by the flexibility of
being able to grab a GOOD site vs one that was much smaller
and un-level and right in the middle of the action.
If we get a warm day when I'm "piddling" around in the garage
I may drain it again but after reading the posts above (and
the owners manual) it's probably fine as is. (Tank is full
of Stabil-ized gas.)
Peace!
Dan & Rita D
11-22-2010, 09:07 AM
Moderator
I just make sure I have a full gas tank that has stabil added and run the genny for abt 10 min. I then shut the fuel off and let it run till it dies. I have 6 small engines I od this with and it have never been let down. In the spring when I turn the fuel on, they all fire on the 2nd or 3rd pull or in the case of the EU3000is it turns over for maybe 2 seconds and starts..
John & Deb
2008 Dodge Ram 2500 4x4 Laramie Hemi Megacab
2011 Flagstaff V-Lite 30WRLS
| Thread Tools |
| Display Modes |
» Recent Threads |
» Online Users: 401 |
| 60 members and 341 guests |
| 09grizzly1, alpinemike, armye7, bikendan, bird_dg, Born2.wander, brookside, Buffalohunter, campdohbrew, camper1953, caper, cfsoistman, Chris Wildwood, dashonthedash, DDC, donn, Ed D, Elanpottery, Emptypockets, F.R.O.G., f1100turbo, frankm, gene17847, grhodes50, Hob, JAJ73, jdudd, JFM-jr, ldmcmahan, lindy, MikeDett, mrmurph, muzbomb, NorminN.B., Oakman, ohiobill, Old car, Papa Roo, ParrotHead, PrairieBoy, rerger, rgmiller32, rkswyo, RubenZ, Shasta1, smcneil, smithmdsmith, tentcamper1, tetsurvivor, TheSasks, thomeyer, tmmar, toybob, Triguy, Txcamper, vcarbona, wbillar, Wildwood Danny, zips2000, zook |
| Most users ever online was 881, 06-22-2011 at 11:07 AM. |
