Old 11-26-2014, 01:47 PM   #11
Here's what I am doing . . .
Next Monday morning my Puma goes to the dealer to have a 20 amp solar panel and controller installed. Thanks to all for the advice and great replies. Happy Thanksgiving!
2 Sooners is offline   Reply With Quote
Old 11-26-2014, 01:59 PM   #12
MilCop4523's Avatar
I jsut took both of mine in the basement and fully charged them, then i put a battery minder on ot which will regulate the charge state throughout the winter.
Harbour Freight sells them and they have worked well for all my batteries during off seasons.
09 Sundance 31.5 XLT Bunkhouse
17 Greywolf 22rr Toy Hauler
and
The new toy hauler - 2016 Ford F150 Supercrew XTR ECOBOOST.
MilCop4523 is offline   Reply With Quote
Old 11-26-2014, 07:40 PM   #13
20 amp solar panel? WOW!
2011 Traverse LT, 3.6L, FWD
rockfordroo is online now   Reply With Quote
Old 11-26-2014, 07:43 PM   #14
Flybob's Avatar
20 Amp or 20 watt?
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 11-30-2014, 08:01 AM   #15
derek6669's Avatar
Just a reminder if you take the battery out to store in basement or garage do not leave it sitting on a cement floor
derek6669 is offline   Reply With Quote
Old 11-30-2014, 08:07 AM   #16
Herk7769's Avatar
Myth busted long ago.
Was true when batteries were in rubber boxes; but not since.
http://www.batterystuff.com/kb/frequ...ete-floor.html
HAM CALLSIGN - KC3FFW
Old 12-01-2014, 02:04 PM   #17
Oops! my mistake . . .
20 watt - with a controller to maintain the charge.
Old 12-01-2014, 04:10 PM   #18
offroad's Avatar
I leave my batteries installed for winter storage.
Our boat and RV have electronics that will slow drain a battery, so both have a disconnect switch.
Prior to winter storage I top off the cells with distilled water, and clean posts as needed.
To make charger connections quick, I installed a 12V power outlet connected to the battery on our Boat, RV and Tractor.
I have pigtail with a 12V plug on it and every month I connect a Shumacher charger, plug into the outlet and charge at 5a until the battery is at 100%.
The 12V outlets make hooking up the charger quick, where batteries are harder to get to than opening a hood.
My truck doesn't get used much unless we are pulling or need 4x4, so I also clip the charger to its batteries once a month to make sure they stay ready to go as well.
Our cars are driven daily so not an issue.
2017 Open Range - Light 297RLS, BX1 Gooseneck
2014 Ram 2500 4x4 CCSB 6.7L 68RFE
offroad is offline   Reply With Quote
battery, winter, winterize
