Old 02-09-2013, 12:28 AM   #21
We used a full 20lb over a weekend due to the heater running alot. I refilled a week ago and paid $3.62 a gallon in Northern California.
John And Mary
2013 XLR 27 HFS
2013 CHEVROLET 2500 6.6 DURAMAX
Nights Camped 2012 (7) 2013 (33) 2014 (27) 2015 (34) 2016 (4)
Kaboom is offline   Reply With Quote
Old 02-09-2013, 08:39 AM   #22
caper's Avatar
If you go with the 30# tanks you should only have to change the threaded rod in order to hold the tanks in place.
Terry and Janet
2008 3001W Windjammer
2007 Ford F150
Old 02-09-2013, 09:17 AM   #23
2011 Forest River Stealth
rwtdct's Avatar
Back when I ordered my toy hauler it was to come with two 5gl tanks. I upgraded to two 7gl tanks do to the fact the biggest precent of the time I dry camp. And yes running the heater threw out the night you will be changing tanks frequently. We normally donot use a heater at night, we use a goose down comforter, boy does it keep you warm at night (a little expensive but worth it). Cold mornings when I get up I will turn the heater on for a while.
Get the bigger tanks.........
2011 Stealth CSFCK3214
2003 Ford F250 Crew Cab 4X4 7.3
2011 Polaris RZR 4
rwtdct is offline   Reply With Quote
Old 02-09-2013, 09:46 AM   #24
BillyBass's Avatar
That is a great price.Before I bought mind Flagstaff I only use one tank a year and I switch it over on Labor Day. I use my Flagstaff 24 nights last year and I still on the same tank I wonder if it is the water tank because it gas and elec.If I was you guys I would buy a little elec heater.
2012 21' FR Micro Lite FBRS
2005 GMC Sierra 1500
2012 24 nites 2016 16 nites
2013 25 nites 2017 19 nites
2014 14 nites
2015 16 nites
BillyBass is offline   Reply With Quote
Old 02-12-2013, 08:48 PM   #25
jtrader's Avatar
My two pennies would be to check your insulation. When its 45 degrees outside the wife and I have to turn on the AC to keep our 28BH below 75. We've had two spells so far with 2-3 nights straight in the single digits and only gone through 1.5 20lb tanks since mid December. we aren't boondockers though. We're on shore power and use an electric heater as primary heating but use the furnace as backup to make sure the overnight stays around 65. We also use a lot of propane with the water heater and stove. From late july to mid december I went through 40lbs. For the winter I bought an extra 20lber from U-Haul that has the built in guage for $35 just to make sure I always have enough in case the space heater goes down or something. I'm not sure they sell bigger tanks though. Good Luck
My TT: 2013 Cherokee Grey Wolf 28BH
jtrader is offline   Reply With Quote
Old 02-12-2013, 09:03 PM   #26
mshell56118's Avatar
place here in Elkhart IN fills 20 lb tanks for 13.99 and after 5 fills you get one free
mshell56118 is offline   Reply With Quote
Old 02-12-2013, 10:45 PM   #27
Local Pro. dealer 20#-10.00$ 30#-15.00$ 2/12/2013 Youroo!!
Old 02-13-2013, 07:26 AM   #28
jimh's Avatar
i always thought the hot water heater was the gas hog. i use to go thru a 40# tank/yr. didn't use the furnace. when i purchased the current trailer, our first night was in sub zero weather (to us...it got down to 28 F). we used the furnace. when i got home i had gone thru one tank and most of the second. yeah...the furnace is a hog.
Sense i started buying propane, i've often wondered why the retail price is close to that of gasoline and there isn't a road tax on the propane. I can remember times when propane was backed up to the refinery, the wholesale price plunged, but the retail price didn't budge.
jimh is offline   Reply With Quote
Old 02-13-2013, 08:29 AM   #29
Herk7769's Avatar
IN THE BEGINNING...
Propane and a few other high fraction gasses were "flared off" from high towers at refineries as "waste gas." How times have changed.
HAM CALLSIGN - KC3FFW
Old 02-13-2013, 08:43 AM   #30
jimh's Avatar
herk, how true. any movement on the flare now prompts a search.
i heard tails of a couple of the control rooms that would use propane to cool their control rooms (not approved by the co). they would vent the other side to the flare. even though, they would have to discontinue the practice (when word got too far up), it shows how little concern there was for the light gas. then they were more concerned abt the safety aspect than the loss of gas.
when i started in the mid 60's, that was no longer done.
