Old 06-20-2014, 09:41 PM   #1
How to access back of TV mounted on wall above fireplace
I have a 32" avenger travel trailer and want to hook up satelite but can not figure out how to get tv off the mounting bracket to gain access to cable on back of tv .. there is no room to reach behind the tv and its fixed solid on the bracket
Rob1964 is offline   Reply With Quote
Old 06-20-2014, 09:49 PM   #2
Platokidd's Avatar
Hey Rob, what model do you have. Sometimes pics are helpful too.
Sent from my DROID RAZR using Forest River Forums mobile app
2014 LaCrosse 323RST-TE-C
2009 Chevy 2500HD Z71
nights of camping
2017-67 / 16-92 / 15-73 / 14-60 / 13-33
Seasonal
Old 06-20-2014, 11:20 PM   #3
Infractee
On our last camper you just lifted the tv straight up then forward.
RhoZeta is offline   Reply With Quote
Old 06-21-2014, 04:10 PM   #4
It is a 2013 31ft avenger touring edition the tv is a legend modenot sure how to attach pics I click on insert pic and it wants me to enter a URL instead of attach a picturel
Old 06-21-2014, 04:21 PM   #5
RSchleder's Avatar
If it's a fixed mounting bracket, the post above is correct. You lift straight up and it should release. If it's an articulating arm type of mount, pull the TV away from the wall and there is a lever to release the TV (and a portion of the bracket) from the wall mount.
RSchleder is offline   Reply With Quote
Old 06-22-2014, 02:20 PM   #6
I f your TV is mounted close to the wall, look behind the tv from each end and you should see a screw on each side of the mounting bracket, remove each screw with a long handle screw driver and lift straight up. I just removed the tv in our bedroom this way, yours may be different.
Gee Whiz is offline   Reply With Quote
Old 06-22-2014, 02:39 PM   #7
Ford Idaho's Avatar
Mine is a flat mounted bracket that has a red plastic coated locking lever on the left side that can be reached from behind and under the tv.
A flashlight might help.
Old 06-22-2014, 04:48 PM   #8
Mine has a lever on the back right. Push the lever in and pull the bottom of the tv out and then up.
jwedell is offline   Reply With Quote
mount, tv mount
