Old 07-02-2018, 09:21 PM   #1
How to cover skylight in shower
We have a 2018 Forester 3011DS. It has a skylight in the shower that allows so much sun and heat to build up that it spills over and heats up the motor home. Has anyone found a way to cover this plastic skylight to keep the heat and sun from coming in without totally blocking the light? I'm thinking of painting it.
Sherol is offline   Reply With Quote
Old 07-02-2018, 09:50 PM   #2
I used white spray paint on the outside of mine. I would do it again in a heartbeat. It cut the heat and still let some light in.
Sent from my Pixel 2 XL using Tapatalk
2015 Sunseeker 3170ds
TakeItEasy is offline   Reply With Quote
Old 07-03-2018, 06:28 AM   #3
jeff64's Avatar
I painted mine on the inside mating surfaces with rustoleum frosted glass spray. Remove inner bezel. Prep both inside surfaces with alcohol, dry and apply the paint to bottom of dome and top of bezel. After it dries, reassemble. You end up with a translucent white skylight and corresponding reduction in temp.
2016 Flagstaff 27VRL Emerald
14K Equalizer
2014 GMC 2500HD CC 4X4 6.0L
Old 07-03-2018, 06:38 AM   #4
I took the inner dome out, lined the top of the inner dome with solar blocking screen from Home Depot, and reinstalled. The outer and inner dome sandwich keep the screen in place nicely. I am not sure if yours has the same 2 dome setup but if it does, it is a quick easy mod to do.
Sent from my SM-G900V using Forest River Forums mobile app
birdman77 is offline   Reply With Quote
Old 07-03-2018, 07:06 AM   #5
Citrus County, Fl.
GL1800Rider's Avatar
I use the Camco insulated door cover on mine and attach with Velcro so it can be removed when we want the light.
2016 Forester 3011DS
2017 Toyota Corolla SE toad
99 Terry 31G
GL1800Rider is offline   Reply With Quote
Old 07-03-2018, 07:10 AM   #6
Head Rambler
Our last RV we wanted all the light blocked out from the skylight, so I painted the outside of it with 3 coats of white paint then 3 coats of black paint and then 3 more coats of white paint. I used paint for plastics and when we got rid of that RV the paint and the skylight plastic dome were still just as good as the day I put it on there. I alternated the white/black/white because I didn't want it to appear black on the inside and I added the black in the middle step to help stop light transmission then I added the white as the topcoat to reflect the sunlight.
If you leave the black coat out and put 2 or 3 coats of white on it, it should block out some heat and light but pass a little.
Gotta go campin!
Old 07-03-2018, 01:25 PM   #7
I just started a similar thread the other day in the Roo/Shamrock forum. Not sure how much it will help, as we have rectangular skylights (while I know some are square), but in case it helps:
Cover options for bath skylight in 23IKSS
Also - I did get one of the Camco door window insulators, and it fits perfectly. So I used some heavy duty white velcro to affix it to the edge around the skylight, and that way I can remove it/put it on whenever I want. Will try it out this week on our next trip. :-)
2017 Rockwood Roo 23IKSS
2017 Ford F150
2018 Days Camped: 34
2019 Days Camped: 5, but many more planned!
Maman325 is offline   Reply With Quote
Old 07-03-2018, 01:46 PM   #8
Cypressloser's Avatar
Location: Alberta - East of the Rockies, West of the Rest
Either reflectix, preferably on the outside, held in place by Velcro at the corners or a few coatings of Plastidip. Plastidip peels off at the end of the season and leaves no residue, unlike some of the off brands.
2018 RAM 5500 Laramie CC
Riverstone Legacy 38RE, 960 Watt Solar, 6x6 Volt AGM Battery Bank, Freedom SW 3012 Inv/Charger
Cypressloser is offline   Reply With Quote
Old 07-03-2018, 02:43 PM   #9
White spray on plasti dip works great
milton_w_herron is offline   Reply With Quote
Old 07-03-2018, 02:49 PM   #10
I did the white paint for plastic 2 years ago. It cuts the heat and still lets light in.
2015 grey wolf 27RR
2015 Chevy 3500HD
kcmusa is offline   Reply With Quote
cover, light, show, shower, skylight
