Old 04-23-2013, 06:58 PM   #1
How to remove adhesive from vinyl decals
Our Cherokee Wolf has faded and mostly peeled off the camper. We want to remove the adhesive but are having a hard time finding something that won't also remove the paint underneath.
Any suggestions?
TIA
scchasgal is offline   Reply With Quote
Old 04-23-2013, 07:01 PM   #2
MI Camperz
bodzcampers's Avatar
Detachol.........Medical Supply Store........has petroleum distillates, but no acetone..........used in Pediatric ICU for it's gentleness. Test an area.
MI Camperz
bodzcampers is offline   Reply With Quote
Old 04-23-2013, 07:01 PM   #3
crunchman12001's Avatar
Goo-gone works well. You will still see a ghost image due to fading though.
crunchman
2015 F-250 FX4
Old 04-23-2013, 07:14 PM   #4
crunchman
We tried goo gone and it is not taking it off but thanks for the suggestion.
Old 04-23-2013, 07:16 PM   #5
Thanks we will try it.
Old 04-23-2013, 07:26 PM   #6
Stanleyg's Avatar
Believe it or not, but try WD40.
Stan, Wanda, Sheray, Alex, Nicky, and Macky(the Chorky).
2013 Prime Time Avenger 33BHS
Stanleyg is offline   Reply With Quote
Old 04-23-2013, 07:40 PM   #7
I have used brake cleaner on my work van to remove old letters. Heat gun for the vinyl then sprayed the adhesive with the brake cleaner to clean.
jsKuchinka is offline   Reply With Quote
Old 04-23-2013, 07:45 PM   #8
2007 WildCat 32QBBS
18CrewDually's Avatar
I use a rubber wheel on a drill. It's designed for removing vinyl graphics and pinstriping from autos. I bought it at Napa for about $35. Yes expensive, but will not damage any painted or gell coat.
18CrewDually is offline   Reply With Quote
Old 04-24-2013, 10:54 AM   #9
Any penetrating oil should do the trick. There is lube/cleaner made by Walter called X-force. It will remove adhesive and inks. It is non-toxic and sorta smells like chocolate.
brewmech is offline   Reply With Quote
Old 04-24-2013, 11:10 AM   #10
HONDAMAN174's Avatar
I agree with the heat gun/ hair dryer method- just not the brake cleaner. That has a high probability of damaging the paint. We use isopropyl alcohol from cvs. Does surprisingly well.
Just glad to get away
Old 04-24-2013, 11:11 AM   #11
Happy owner SOB
X2
sheriff1 is offline   Reply With Quote
Old 04-24-2013, 07:29 PM   #12
Thanks all. The decal is completely gone what is left the the backing of the decal. We are heading out to the storage on Saturday and I will let you all know what works for us without going down to the aluminum.
Old 04-24-2013, 07:32 PM   #13
You may have to take a little polish to the paint as many times a shadow of the decal will remain
Old 04-24-2013, 07:55 PM   #14
Thanks we are hoping to replace it with what was originally there if we can get it.
Old 04-26-2013, 07:02 AM   #15
heat gun but be careful it will peel the paint if held too long in one direction. WD-40 usually takes it off be careful with brake cleaner it may remove paint on some surfaces. If not in a hurry peanut butter will loosen the adhesive. I worked at a van conversion factory the guys used the heat gun and a piece of wood shaped into a wedge as a scraper to remove the graphics then lacquer thinner to remove excess adhesive.
brokenaxle is offline   Reply With Quote
Old 04-26-2013, 07:13 AM   #16
Bodean614's Avatar
PVC pipe cleaner will remove the glue. I used it on removing my truck decals.
Bodean614 is offline   Reply With Quote
Old 04-27-2013, 05:40 PM   #17
We went out this morning and the PVC pipe cleaner also removed the paint down to the metal. Yes it takes it off easy and we are going to continue and then paint.
Old 04-27-2013, 05:50 PM   #18
Stanleyg's Avatar
The WD40 will not hurt the paint and will take the glue off. I tried it on one I had on my TT and it worked no problem, took a little elbow grease, but no damage to the paint at all.
Old 04-27-2013, 07:03 PM   #19
Bodean614's Avatar
I had no idea it would remove the paint. Like I said I used it on my truck much better paint.
Old 04-27-2013, 10:44 PM   #20
TURBS's Avatar
Sticker off.
