03-01-2014, 02:54 PM
how to remove sofa
DIY. I have a lacrosse 311 rls. I want to replace the sofa with recliners. My question is how to remove the sofa from the floor. the front corners of the sofa are free. The rear corners are attached. they are large round (ball) type and I cannot find how they are attached.
HELP
03-01-2014, 02:59 PM
I'd see if you cab look underneath maybe? I wouldn't think they'd screw from bottom up, but who knows?
Sent by me
Joel and Teresa
2016 Sabre 34TBOK
2006 GMC 3500 CC LB DRW 4X4
03-01-2014, 03:01 PM
What kind of sofa? Is it flip out with air matress or newer lane kind?..pic
I took mine out...but cant remember how it was attached.?
sent from fat fingers via a space dish thing with no regard to grammer.
2015 F350 Platinum Fx4 6.7 Diesel Dually. B&W turnover, B&W Companion, air bags and wireless controller.
2015 Heartland Road Warrior 420 Rt
2012 f250 Fx4 6.7 Diesel crew cab tinted n tuned
2012 lacrosse 318bhs touring- sold
03-01-2014, 03:37 PM
it is the flip out with air mattress. It sets on round (soft ball size) legs at each corner. the front two are not attached. it is attached at the back two.
03-01-2014, 04:04 PM
If you open it up into the bed position and look through the framework you should see a couple of straps holding the frame to the floor with screws.
Dave
03-01-2014, 05:00 PM
Yes...I do remember now having to remove drawer and flip open couch to gwt out straps/bolts......
03-01-2014, 05:30 PM
GOT IT!!!!!!!!!!!!
There is a wood brace 1 X 2" that runs side to side that had 2 long screws thru it and into the floor. once removed, the sofa is ready for removal from camper.
Thanks everone
Gene
03-01-2014, 06:37 PM
I took the sofa out of my Vlite too. Did it by myself and had to stand it up on end and partially open it up and wiggle it through the door with an 1/8" to spare on each side. I would not recommend doing it by yourself(like me) but I am stubborn and was determined to show the BOSS I could do it. The manufacturer must have loaded the couch before the slide was attached. I have 2 recliners that sit side by side while traveling. When parked, I pull 1 out to face the tv and leave the other angled diagonally to the tv.
03-06-2014, 12:27 PM
OK, Replaced with a Love seat recliner with console. Do I need to screw it down to the floor?
03-06-2014, 04:22 PM
I would, maybe with a plastic or metal strap attached to the back legs of the loveseat. It may not move without it but what the hey!
03-06-2014, 04:34 PM
I would use the same screws that came out, if you can use the same holes so as to avoid running one into a power wire or plumbing.
03-06-2014, 04:41 PM
Thanks for confirming. I knew I should, but gonna be a hassle to get to the back side.
03-06-2014, 04:46 PM
Do the backs come off?
You might give that a look see I know it will be a lot easier if they do.
If you are not sure call the place where you bought it at.
