Old 10-12-2014, 12:52 PM   #11
arpipeliner's Avatar
In the past using a light duty hose if tighten too much. It will pull/push the metal connection apart and make a leak. Use heavy duty hoses now they cost a little more but no issues since.
As stated above the suggestions will all stop the leaks. If it's the CG hydrant it could be bent or threads messed up. Have seen that.
arpipeliner is offline   Reply With Quote
leak
