Old 06-24-2014, 05:34 PM   #1
prof_fate's Avatar
how to stop leaky hose connections?
Last CG we stayed at there were 4 water hookups and Ihave 2 hoses and a filter..NOTHING I did could get water to stop leaking/spraying even from the connection to the, well, hose bibb I guess you'd call it.
I've had drips in the past and carry spare washers..never had luck using stacked washers (didn't try that). Did try pliers and gorrilla tight..to no avail.
Any suggestions?
Chris, Wills (16) Evie (13) & Toby our collie (6)
2011 Grey Wolf 28BH
2013 Chevy K1500 Crew w/ Reese StraitLine Dual Cam
Nights camped 2011: 11 2012: 18 2013: 12 2014: 12 2015: 13 2016: 56 2017: 8+
prof_fate is offline   Reply With Quote
Old 06-24-2014, 05:48 PM   #2
NELA
Weezer's Avatar
As I said in a similar thread:
Teflon tape on the male threads of the hose!
If age is a state of mind, and I've lost my mind, I'm AGELESS, right?
Give me 40 acres and I'll turn this rig around:
Flagstaff 5er 2014 8528 IKWS, Platinum Package, Regency Interior "Buffy"
F250 Super Duty 2013 Tuxedo Black "Biff"
Days camped 2014: 30
Weezer is offline   Reply With Quote
Old 06-24-2014, 05:57 PM   #3
TURBS's Avatar
Npt. Pipe thread is great for the use of Teflon tape.
But very unlikely to work on a straight thread that requires a gasket to seal.
Normally the leak on a hose to hydrant connection is a faulty gasket, dented hydrant end , bad threads or a loose hose nipple crimp.
Old 06-24-2014, 06:18 PM   #4
prof_fate's Avatar
How would that work? IN this instance the bibbs all had what appeared to be short thread length..no amount of tightening got the washer to compress - water was coming out between the hose and the hose 'nut' - NOT from the thread ends/at the bibb.
2011 Grey Wolf 28BH
Old 06-24-2014, 06:20 PM   #5
NELA
Weezer's Avatar
(shrug) Works for me!
YMMV
Old 06-24-2014, 06:35 PM   #6
TURBS's Avatar
Sounds about right.
I keep a piece of "trucker" mud flap for instances such as that.
Stacking washers "seldom" work.
Mud flap is thicker and won't squish out.
Old 06-24-2014, 06:41 PM   #7
BOBFIDY's Avatar
The city water hook up on our trailer started leaking...no matter how tight I tried to get it.....until I started wrapping Teflon tape on the male end of the garden hose. My final thought was that the plastic threads in the female connector on the trailer and worn out, and the Teflon tape worked until our last trip. I have now replaced the connection piece on the trailer with a new piece that is mostly brass vs. the old all plastic piece. We will see how well the fix works next week on our next trip.
2011 FORD F350 CREW CAB DUALLY DIESEL 4x2
2010 Salem LA 292FKDS
One of the Original 14 F.R.O.G.s
1st, 2nd, and 3rd INTERNATIONAL F.R.O.G. RALLY Branson. MO.
1st, 2nd, and 4th INTERNATIONAL RALLY Goshen, IN.
BOBFIDY is offline   Reply With Quote
Old 06-24-2014, 06:47 PM   #8
prof_fate's Avatar
On that end it may work - our connection got 'tweaked' at some point (someone tripped or pulled the hose I"m guessing..kids, pets, etc). And the leak was in the thread to hose - but that end appears different from the bibb end.
I 'tweaked' it back into working order so didn't have to replace it. So far replaced the door hold open rod - not bad for 3 years I guess!
2011 Grey Wolf 28BH
Old 06-24-2014, 07:09 PM   #9
B and B's Avatar
X2 when brand new. The stamped hose fitting don't work I used a 90 degree machined brass elbow and all was well.
2017 Heartland Bighorn 3575 Elite with Reese Sidewinder
2016 Ford F 350 SD PS 6.7 SRW Crew Pucks and Reese 18 K Elite
2013 Rockwood 8289WS 2012 Rockwood 2703 SS TT 2007 Golden Falcon 38FLA PM 1983 Corsair 21RB
2015 Ford F250 PS '13 F150 3.5 Eco '09 F150 5.4 l 1987 Merc Grand Marq 1982 Ford E250 CW
Old 10-11-2014, 11:13 PM   #10
Keep extra washers handy.. replace them if they start leaking.. if you find that the washer is good but it still leaks try doubling up.. 2 washers.
Hose connections use teh threads for compression.. the washer is what creates the seal, sometimes doubling up on teh washer can add extra material for greater compression and stop a leak.
RollingBlunder is offline   Reply With Quote
leak
