Old 09-02-2017, 02:25 PM   #1
Humidity
New to camping, should the humidity be kept as low as possible when in storage?
captain bill is offline   Reply With Quote
Old 09-03-2017, 09:48 AM   #2
Jim34RL's Avatar
If possible yes! I use Damp-rid and let this absorbed the moister from the interior of my trailer when in storage. We empty the contents before moving the trailer out of storage. We check this every other month when the unit is in winter storage, low humidity in the winter.
Jim W.
2016 34RL CC; 2008 Ram Mega Cab 2500HD, 6.7L, 68RFE 6 speed, 4X4, Smarty S67, TDR 123K+miles
Old 09-03-2017, 10:32 AM   #3
We have a small TT (R-Pod) and use two gun-vault refreshable dehumidifiers. We check them every month.
eye95 is offline   Reply With Quote
Old 09-03-2017, 10:53 AM   #4
Thank you all!
Old 09-06-2017, 09:28 PM   #5
Humidity
What is the target number you are trying to keep the humidity at? I didn't even know I was supposed to be monitoring this.
SALEMS LOT is offline   Reply With Quote
Old 09-07-2017, 08:03 AM   #6
We have 2014 crusader use damp rid but about to go through hurricane Irma ? Any advice on storage?
Elephant is offline   Reply With Quote
Old 09-07-2017, 08:09 AM   #7
Prime Member
My suggestion is out of state. Perhaps TN.
2016 Coachmen Freedom Express Liberty Edition 310BHDS
2013 Chevy Silverado 2500HD LTZ 6.6L V8 Duramax
Husky weight distribution hitch with sway control
Forever in my memory and in my heart. Laurie J. Wood 3/22/67 - 8/23/19
timfromma is offline   Reply With Quote
Old 09-07-2017, 08:16 AM   #8
Jim34RL's Avatar
I would try to leave the area possible traveling up to the golf Shores or so. If this is not possible make sure that you have insurance that will cover the damage to the trailer and contents from hurricanes!
That is about all I can suggest. I know I have coverage if a tornado hit my trailer when in storage.
Jim W.
Old 09-07-2017, 08:18 AM   #9
Flybob's Avatar
It can get pretty humid in MD is the summer and I have had issues with slight mold problems in past RVs. As i keep the TT next to the garage ( power available) I run a small household dehumidifier when the temp is above 45F. I have on with the drain hose option and ran the drain through one of the existing access holes through the bottom of the unit. I keep it set at 45-50%.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
