Old 11-09-2007, 09:19 PM   #11
welshman599's Avatar
Send a message via MSN to welshman599
Ewwww. Not Feminine bath products! That's not Man territory what with the loofas and oils and whathaveyou. We feel your pain man... here, hold this nail gun for a minute, it will help with the dizziness.
  • Salem 401-2b; 31" Sony Trinitron and two channels on the antenna.
  • Smokin' hot wife... 2 boys, 25 and 10.
83 sweet sweet days camped in 2008 - not easy in my neck of the woods!
welshman599 is offline   Reply With Quote
Old 11-12-2007, 11:02 AM   #12
Florida Member
Scuba Stan's Avatar
I guess Calgon is NOT going to "take me away". I have talked to people smarter than myself, which isn't hard to do, I'm going to try cascade dishwasher detergent. I guess the " sheeting action" would do the same thing as the calgon. It's septic tank safe so it shouldn't cause any trouble in the holding tanks, so we'll see. I'll know after this weekend, I'm going to add some tonight and leave it until we dump the tanks Sunday.
'67 Scuba Stan, starting to show signs of wear
'04 Dodge 2500 Quad cab, 5.9 Cummins, low miles
'04 Cardinal 29LE, like new
'92 Son, Barely used
'71 Wife, spoiled rotten, but in great shape
'99 Miniture Cocker Spaniel, spoiled rotten, almost as much as '71 wife.
'08 "Chug", running in a dead tie for second as far as being as spoiled as '71 wife.
Scuba Stan is offline   Reply With Quote
Old 11-12-2007, 01:52 PM   #13
so, if you use the water softener etc, did I understand the original article to say that you do not need to use black tank chemicals??? I would think that I could use both, use the water softener to clean the sides of the tank and the chemical to break down the solids. Did I misunderstand the original author? - Thanks
Crosshill from OK
Wildwood M29+3 TT
crosshill is offline   Reply With Quote
Old 11-12-2007, 02:18 PM   #14
Florida Member
Scuba Stan's Avatar
A lot of rv parks ,down here at least, don't like the blue chemicals in their septic systems. I take it as an alternitive to the chemicals, in theory keep it clean to start with and you won't have the smell to cover up. I've always been told if you are using septic safe paper and dumping the tank when it's at least 2/3 full you shouldn't need chemicals. It never seems like it works out that way with the heat in Florida, but I'm hoping to kind of get a "fresh start " since we recently purchased this fifth wheel. I hope this helps.
