Old 06-09-2012, 09:32 AM   #1
Incorrect Panel Black Water/Propane Tank Readings
Just got our used 2007 Lexington 283GTS and are having problems with interior master panel that gives readings on the waste water levels and propane tank level. Drained the black/Grey water this past weekend after a short trip but the Black tank indicator still indicates full while the grey tank is ok at empty. Also, The interior propane reading is 2/3 full while the gauge on the outside near the tank indicates only 1/3 so don't know which one is correct. Any suggestions as to what my problem is with the interior panel?
rpgibbs is offline   Reply With Quote
Old 06-09-2012, 09:37 AM   #2
TURBS's Avatar
First u should not post your email in an open forum.
Second you should not go by tank gauges they are not even much of a guide if you will.
In the black tank tp will stick to the probes and throw off the readings.
Flushing the tank and also not leaving empty helps.
Also do a search on. Geo method
Old 06-09-2012, 09:39 AM   #3
Great Horned Owl's Avatar
The sensor in the black water tank gets fouled with bits of toilet paper, etc. A good tank cleaning might help. All propane tank gauges are unreliable except those that actually weigh the tank.
2011 Silverado 2500HD Duramax, 4x4, crew cab, long bed
Palomino Puma 253-FBS, 27' 5th wheel
1994 19' Class B on Chevy chassis
Great Horned Owl is offline   Reply With Quote
Old 06-09-2012, 09:45 AM   #4
As for the propane, go by the outside gauge, it is in the tank, and while maybe not 100 percent, it is the better gauge. Others have mentioned the black tank solution, maybe.
If you search in here, some have recommended 5 gallons of water, then two bags of ice, and go for a ride. The ice will help scrub the walls of the tank, knocking anything loose.
LadyWindrider
2012 Ford F250 ext. Cab 4x4
2002 Jeep Wrangler Sahara
2008 Work and Play 18LT
Old 06-10-2012, 06:22 AM   #5
Herk7769's Avatar
The reason your probes are inaccurate and the permanent fix is located in this thread:
http://www.forestriverforums.com/for...ion-16089.html
My tanks are now perfectly accurate.
Note the photos of tank probe locations. The "1/3" light is actually a "not empty" light since a single flush may turn it on depending on where they drilled the hole.
Lou & Freya the wonder dog
2019 Flagstaff 8529FL
black water, led pad
