08-05-2019, 01:03 PM
Instrumentation Question on F-350
We just purchased a Forester 3051S on a Ford chassis. I find it difficult to believe in today's auto/truck tech world that a vehicle such as this has no external temperature gauge, MPG read out, miles to empty reading, etc. Am I missing the obvious or is this cab a basic delivery van with no helpful instrumentation?
08-05-2019, 01:19 PM
E350 (not F350) owners manual no help?
08-05-2019, 01:21 PM
You may find that these are available, but deep in the 'menu' of your dash readout, if you have one....but, yes, otherwise, many RVs are built on chassis designs that are built for the RV industry, not direct to consumers, and may be more 'basic' than you might expect.
08-05-2019, 04:29 PM
You're correct. It's an E350. I've played around with the setting "stick" going into the center of the dash, but nothing but two trip odometers. I'll pursue the owner's manual again, but I'm beginning to believe that this part of the instrumentation is real basic. Thanks.
08-05-2019, 04:45 PM
There is a factory option for a more in depth trip computer on the E350 although FR does not order that option on their chassis.
You will find 2 other options available with the ignition on but engine off to set the operation of the door locks.
2021 Newmar Baystar 3401
2019 Jeep Cherokee Trailhawk toad
2017.5 Forester 3051S Traded 7/2020
08-05-2019, 05:02 PM
Thanks. Seems odd that FR would offer such a base option. Wonder whether the factory options you mention are possible in the after market. Probably too expensive to justify even thinking about. But, it sure would be nice to know the outside temp as your driving along. Thanks again
08-05-2019, 07:54 PM
I believe the option is just a software toggle in the ECM/BCM. Most likely not offered as an after build upgrade. I know for a fact that the ambient air temp sensor is in place and functions as the ECM uses that data. I use a scan gauge which pulls the data from the ECM. I have one of the 4 data displays set to display the temp.
08-07-2019, 12:02 PM
If you are really brave you might try FORScan. I got the connectors but haven’t had the courage to go into the ECM and mess with it. You can make changes and turn some features on and off. Google it and see what you think and good luck.
08-07-2019, 01:19 PM
Forscan will show what "modules" are in the system. There's a way to get all the Module Build Data ("as built") settings from motorcraftservice dot com. I have mine but have forgotten how to down load it. The "as built" data is in hexadecimal with no ascii or text data.
There are Forscan forums, or sub-forums, on line.
-- Chuck
08-07-2019, 01:26 PM
Part-Time Campground Host
Most cell phones can show OAT on the home screen.
Craig & Cath
Days camped since 2015(retirement): 1687
08-07-2019, 01:36 PM
Really? Never seen it on any of the dozen iPhones in my extended family. Sure I can get the temperature in Richmond but that's not the same as the OAT where my phone is sitting.
-- Chuck
Don't know about the MH but on my F-350 the temperature for outside is right at the top of the sync display. 100 degrees today. Nice.
2016 F350 CC Dually Powerstroke 4x4
2014 Cedar Creek 34RLSA w/Level Up
2007 HD Ultra Classic 103
USS Pyro AE-24 WestPac MM2 '71-'75
08-07-2019, 01:43 PM
-- Chuck
My Android Pixel 3 follows my location.
Craig & Cath
08-07-2019, 01:48 PM
IPhone doesn't support live widgets like Android. IPhone is about 12 years behind Android in this respect. Luckily, I read that Apple IPhone sales are fading and that the death of that horrible device may be in the distant future. I doubt it would be missed.... junk.
2019 Ram Bighorn, CC/SB 2500 4x4 6.4L/8 Speed, Max Tow 14,460 lb/2,940 lb payload.
2019 F-150 King Ranch 3.5 Eco, 12,800 lb/1,546 payload.
2020 Coachmen Apex UL 289TBSS
2019 Quality Trailers 16'x7' 7K GVWR Utility Trailer
2019 IronBull 22'x102" 14K GVWR Equipment Trailer
08-08-2019, 03:15 PM
I'll look on mine to see if it is there. Thanks.
08-08-2019, 03:16 PM
I'm going to check into your recommendations. I think it might be too complicated for what I ultimately find to be missing.
