01-29-2016, 11:09 AM
Is 50 Amp power better than 30???
My Rockwood runs on 30 Amp power. If given the choice, should I use the 50 Amp plug with a 30 Amp adapter for a more reliable power supply to the RV? I've heard people say this a more constant 30 Amps than the 30 Amp plug which may fluctuate, and at times be less than that.
[SIZE="3"]Kim & Katie Fay[
Hilton, NY
2022 Cherokee Alpha Wolf 28FK-L
2021 Ford f150 XLT, 5L, Garmin RV760MT
Travel Companions - Zoey and Zeus
01-29-2016, 11:11 AM
I did on my last 30 amp unit.
50 outlet 30 amp adapter
2015 Columbus 320RS
2008 2500HD Duramax
2015 nights camped "34"
01-29-2016, 11:17 AM
I think the bigger benefit is that the 50A socket gets used (and abused) less, so will make better contact then the 30A one may...
A 30A circuit is designed to be used to 24A (80% of rated OCP) - A 50A circuit will have more available power; so if you're pushing the 30A to it's max, there may be an advantage to using the 50A.
Last thought - 30A trailers are more common, so depending on how the posts are wired, there may be more load on the 30A "side" of things, which could lead to less stable power - but that's very much dependent on how the park and post are wired.
2014 Grey Wolf 28BH, behind a 2015 F350 Diesel Crew Cab
Nights Camped 2016: 44
Nights Booked 2017: 11
Nights Camped 2017: 6
01-29-2016, 11:25 AM
A Good 30 is all you need! 50 A adds nothing to your 30 A service! Youroo!!
01-29-2016, 11:48 AM
The key word there is GOOD!
True, a 50 amp outlet (through an adapter) won't allow your 30 amp rig to utilize any additional power that a correctly balanced, properly wired 30 amp outlet will... but in the real world, those pristine 30 amp'ers seem to be fewer and farther between.
I'll always take the 50 amp outlet if available.
Days Camped ☼ '19=118 ☼ '20=116 ☼ '21=123 ☼ '22=134 ☼ '23=118☼ '24=64
01-29-2016, 12:02 PM
When In Nashville last year I was plugged into 30 amp, about noon I was down to 102 volts.
Plugged into the 50 and was back up to 112v
My recent experience.
2015 Columbus 320RS
2008 2500HD Duramax
01-29-2016, 12:40 PM
IMO a 30 amp receptacle is better. A 50 amp service provides about 25 amps on each leg. So if you are trying to use one leg of a 50 amp circuit you are not going to be able to run close to 30 amps. When I tried running with one leg of the 220 receptacle on my generator it kept kicking the breaker. When I ran off the 30 amp 110 receptacle there was no problem.
01-29-2016, 12:51 PM
I'm not sure this is correct. 50 amp service should provide nearly 50 amps on each leg.
01-29-2016, 12:59 PM
2015 Columbus 320RS
2008 2500HD Duramax
X-4 Has always been my experience also. Places I visit, 30a s always browning out. Sometimes 95-105 volts. 50 amp doesn't seem to have that problem.
01-29-2016, 01:01 PM
This is correct, that a split phase 120/240 campground service is capable of providing 50 amps PER leg or a 100 amps total.
This is often misunderstood by many. These links may help out:
Electrical Tutorial - Chapter 3 - 30 Amp versus 50 Amp
Click the 50 amp tab on left for this one:
RV Electric
AC Electricity
Here is a good visual:
2011 Flagstaff 831 RLBSS
01-29-2016, 01:04 PM
Georgia Rally Coordinator
2015 Columbus 320RS
2008 2500HD Duramax
X 2 also Later RJD
2018 Dodge Ram 2500 6.4 3:73 gearing. Traded 2015 Chevy 2500 6.0, 4:10
Traded 2015 30WRLIKS V-Lite
Days camped 2019 62
01-29-2016, 01:05 PM
There is not much benefit plugging into a 50 a source versus 30 a source if you have a 30 a RV and both sources are available. The thing you should do is put a surge protector between the source and the RV. That will resolve your concerns.
01-29-2016, 01:11 PM
Was the 30 amp plug on the same post as the 50 amp. The reason I am asking is that the 30 amp plug on the post is supplied with power from the 50 amp wire. So you should not have had a voltage drop by using the 30 amp.
Terry and Janet
2008 3001W Windjammer
2007 Ford F150
01-29-2016, 01:14 PM
Voltage drop on the 30 amp connector is most likely from the worn out 30 amp receptacle. Not making good contact with plug. 50 amp is used less and tighter.
01-29-2016, 01:54 PM
50 Amp
I may be missing something here but using 50 amp service means the breaker is a 50amp breaker. A breaker is a safety device to prevent excess current. If there is a short or wiring fault it will draw up to and including 50 amps before the breaker will trip. That means, among other things, your 30 amp cord may burn up and any electrical items that are in trouble may also catch fire..
Why would you risk your safety?
01-29-2016, 01:58 PM
Not true read my above experience.
2015 Columbus 320RS
2008 2500HD Duramax
01-29-2016, 01:59 PM
Same post for both.
2015 Columbus 320RS
2008 2500HD Duramax
01-29-2016, 02:00 PM
Your 30 amp breaker in your camper will trip before all of what you say happens.
2015 Columbus 320RS
2008 2500HD Duramax
01-29-2016, 02:03 PM
I have found the same thing with the voltage. I can plug in to 30A and get down to 108V. If I then walk outside, move the plug to 50A with an adapter, the voltage immediately goes up. In the winter it doesn't matter quite so much, but in the summer, it sure does.
Ben and Doreen
Home Away From Home - 2017 PT Crusader 315RST
TV - 2016 Ram 3500 Laramie 4X4 6.7 Cummins Diesel
Never Enough Time Camping!!
01-29-2016, 02:04 PM
Here's the reality of it. When you plug your adapter into a 50 amp outlet you may actually be using the other hot circuit that you don't see on the 30 amp outlet. Entirely possible for it to be better. Depends on how rhe post is wired. May help in some places, no difference in others.
