Old 01-14-2016, 11:17 AM   #21
Originally Posted by SKnight View Post
When I winterize I pull the plug, once the tank is drained I then will let a little pink stuff go through the line to the heater to make sure it's protected, then bypass the heater.
Then come spring I will flush out the tank with fresh water. In the meantime I just toss the anode in the bottom of the heater area and put the cover back on.
It's typically recommended that you don't put AF in your water heater. That's the whole purpose of the bypass.
Iwritecode is offline   Reply With Quote
Old 01-14-2016, 06:52 PM   #22
ferguson65's Avatar
I was told by the dealer to leave it out. I made the executive decision to put it in a few threads, as others have posted to keep the critters out. We have a major stinkbug problem and I could just see the WH being full of them if I left the plug out. Actually, I taped the backside of the WH cover so the brown pest stays out completely. I also taped over the heater exhaust and inside the fridge vent. Stinkbugs get into EVERYTHING!
2013 F350 dually
2015 Palomino Puma 351THSS Premier Edition
2015 Nights camped 15
2016 Nights camped 5
ferguson65 is offline   Reply With Quote
Old 01-15-2016, 09:23 AM   #23
SKnight's Avatar
I only run enough AF through to make sure the line between the bypass and the water heater is protected. Once I hear the AF hit the tank, I then turn the bypass, so very little AF actually gets to the heater.
On my TT the bypass was literally right at the tank, so I didn't worry about it. But this 5er has about an eight foot run between the bypass and the heater. I don't know that it was cleared so I protected it.
Old 01-16-2016, 10:44 PM   #24
Ford Idaho's Avatar
Bolded line reads very strange to me, what does the 8 foot run feed/do/ go to?
Old 01-19-2016, 11:18 AM   #25
SKnight's Avatar
My bypass valve is in my water panel in the basement, the water heater is roughly six-eight feet away under the bathroom. Presumably, if I bypassed it then ran the antifreeze through the system, the feed line between the bypass valve and the tank would have water in it.
So I turned the bypass valve, ran antifreeze through the system, then turned the bypass back towards normal until I got just a bit of antifreeze to trickle out of the heater. Then turned it back to bypass.
It got the test last night, 21* this morning.
Old 02-23-2016, 06:52 AM   #26
Does anyone know the size of the socket to use on the anode rod?
Asrabbit is offline   Reply With Quote
Old 02-23-2016, 07:16 AM   #27
Suburban is 1 1/16 6pt socket! Youroo!!
Old 02-23-2016, 08:01 AM   #28
I have an inch and 1/8th. I figured I had the wrong size as it would not be me to have the right size. Thank you for the help. I will get a 1 and 1/16th.
Old 02-23-2016, 08:16 AM   #29
Head over the China freight, you can get one of those large impact socket sets that will have that one for just a few bucks more than buying just one.
Old 02-23-2016, 08:28 AM   #30
SeaDog's Avatar
If you pick up the Pittsburg forge brand socket set at Harbor Tool and Freight they come with the same lifetime replacement as the more expensive snap on, craftsman, or husky tools.
Retired Navy
Jake my sidekick (yellow Lab)
2016 Flagstaff 26 FKWS
SeaDog is online now   Reply With Quote
drain, hot water, water, winter
