Old 10-29-2017, 09:06 AM   #1
Isata 5 dually tire inflation
I am unable to get air into the inner rear tires. I use a "Milton" air chuck. Which is supposed to work. I had a truck tire place put longer metal valves on the inner tires. I am still not able to get to the tire valves.
Is there a long narrow chuck that I need to find better suited than the Milton?
Is there a longer valve stem (metal) that is used?
Has somebody figured this out?
I have the Alcoa Rims.
daveinthekeys is offline   Reply With Quote
Old 11-06-2017, 07:16 AM   #2
raforan's Avatar
i have a chuck that was given to me by the owner of the truck previously that basically threads onto the valve stem on the tire then has flexible hose like the Melvin and is a regular valve stem on the opposite end the put air in. i tried to find a picture on google (im at work) but if i remember ill take a picture of it when i get home
2011 Coachmen Cattalina 26bh SOLD
2016 Coachmen Freedom Express 31SE
2006 GMC 3500 Duramax Dually
2017 Nights Camped 75 and counting
2018 Nights Camped 40 and counting[/b]
USMC 2005-2015 OIF OEF
raforan is offline   Reply With Quote
Old 11-06-2017, 07:20 AM   #3
raforan's Avatar
sort of like this but the female end is threaded.
https://www.diytrade.com/china/pd/99...extension.html
Old 11-06-2017, 09:18 AM   #4
I can barely touch the valve with my finger tips. I don't think I can clamp it down. Though the screw on idea might just work. I will pursue that and try it at home (just incase all the air escapes in the experiment)
Thank you for the idea.
Old 11-06-2017, 09:38 AM   #5
raforan's Avatar
https://www.amazon.com/gp/product/B0.../ref=as_int_dp
tire
