Old 11-23-2015, 09:16 PM   #1
Issue with Turn Signal
I have a 2010 Georgetown Forest River, Ford V10 Chassi. I cannot figure this out. The driver side turn signal (oblong amber) and parking light was not working. Bulb is good. Camper neighbor next to me suggested that the maybe the lower marker light that also works as the turn signal. (round amber one) might have the turn signal bulb burned out. Changed that bulb, but turn signal still does not work.. but now the parking light on both the oblong and round amber works but still no turn signal. Hope this makes sense. Has anyone out there have any suggestions? Trying to figure out why turn signal does not work. (flasher on that side does not work either) Thank you for any helpful suggestions..
dow12 is offline   Reply With Quote
Old 11-24-2015, 05:07 AM   #2
AquaMan's Avatar
Did you replace with the correct bulb? Is it a single or 2 filament bulb? Other than that, would think its a wiring issue. Time to get a meter and start tracing wires
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2019 - 17
Old 11-24-2015, 08:59 AM   #3
Oaklevel's Avatar
If the fuses are good then there could be a ground problem to that side.....
Good Luck !!!!!!!!
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
Oaklevel is online now   Reply With Quote
Old 03-11-2016, 08:56 PM   #4
Appalachian Ed's Avatar
Does the brakelight work on that side? If not it is likely in the feed somewhere. Either fuse/relay in the TV, in the trailer wiring connector, or if they are all good, perhaps painfully in the trailer wiring.
Ed
2015 Rockwood 8289WS
2009 Ford F-250
Appalachian Ed is offline   Reply With Quote
