Old 09-21-2013, 09:25 PM   #1
items list
We are very new to camping. Can any of you me some ideas as to what items are a Must to have in the trailer. Like toilet paper and trash bags things of that nature
david155 is offline   Reply With Quote
Old 09-21-2013, 10:01 PM   #2
Ford Idaho's Avatar
Duct tape, you can never have enough.
Cutting sheets.
Scissors.
Painters tape.
A boat load of Command hooks.
Pad and pen to write down what you forgot the first couple of times.
Rubber gloves.
First aid kit.
Old 09-21-2013, 10:08 PM   #3
Awesome
Old 09-21-2013, 10:13 PM   #4
Here's some additional stuff I carry:
Tool box
Multi-meter
Flashlight(s)
Rags
Pots & Pans
Cutlery
Silverware
Deodorizer for black water tank
Coffee pot
Weather radio
Grease for Weight Distributing Hitch (WDH)
Box of latex gloves for using when working with stinky slinky (sewer hose)
Tissues
Paper Towels
Gallon jug for carrying water when necessary
Chocks
Leveling blocks
2011 Traverse LT, 3.6L, FWD
Old 09-21-2013, 10:18 PM   #5
Ford Idaho's Avatar
Originally Posted by david155 View Post
Awesome
Ya I forgot to put that down.....
Gorilla glue.
Outdoor extension cord 25 x 2 for fifty.
Rope or paracord 50ft.
A small shop vac.
Lego blocks to level out with, walmart about 32 bucks.
Old 09-21-2013, 10:18 PM   #6
I'm seeing so good suggestions here. Thanks
Old 09-21-2013, 10:27 PM   #7
HemiCab's Avatar
Replacement fuses and breaker.
Roll of Eternabond tape.
Emergency repair tape.
HC
2008 Dodge Ram 2500 QC CTD 4x4
2014 Cherokee 284BH
Equalizer 1,200/12,000 WDH
TST 507RV TPMS
MaxBrake BC
HemiCab is offline   Reply With Quote
Old 09-21-2013, 10:38 PM   #8
Ford Idaho's Avatar
Two spare bulbs for every type of bulb you have.
For those times when you need both hands.
For after those times when you needed both hands.
Old 09-21-2013, 10:45 PM   #9
Fire extinguisher
2008 Forest River Micro-Lite 18FBR
2000 Ford Explorer Sports Trac
WBrian is offline   Reply With Quote
Old 09-21-2013, 11:24 PM   #10
asquared's Avatar
White fresh water hose (2x25 ft for 50 ft total)
Water pressure regulator
Sewer hose (we carry over 30 ft)
Clear elbow so you can see when tank is rinsed clean
If you don't have a built in black tank flush, then a wand and a separate long hose to flush tank from inside trailer.
Plumbers tape
Electric tape
Air compressor (ours will also jump a battery if necessary)
Heavy duty chocks
Leveling blocks (we use lynx levelers)
50 ft rv extension cord
30/50 amp dogbone adapter
20/30 amp dogbone adapter
Surge protector
Tool kit with cordless drill (14 v or better)
Extra fuses of all types in your trailer
Battery cutoff switch
Stock the inside like a house with dishes, toiletries etc that live in trailer so when camping you only have to worry about packing food and clothes.... We even have a hand held vacuum and.swiffer that live in our tt.
First aid kit
Camping chairs for outside
Grill
Fire poker
Safety hazard triangle in case of breakdown
Emergency roadside assistance (good Sam ers or coach-net). AAA has to have separate policy in place to tow your trailer for you.
Water filter is optional
If a tt, htt, pup see if you need wdh and sway control (ask and we will help you determine what type and better brands to get
Chemicals for black tank (we like the geo method)
Toilet paper.... Does not need to be rv specific, single ply septic safe is fine. We use angel soft with no issues.
A sense of humor is a must. You have to laugh at your mistakes or you won't have fun
<a href=http://i62.tinypic.com/28rp645.jpg target=_blank>http://i62.tinypic.com/28rp645.jpg</a>
2014 Sabre 34REQS-6
asquared is offline   Reply With Quote
