Old 01-25-2016, 09:59 PM   #1
Kid control
Looking for tips and tricks on how to keep little ones in their bunk bed. I have a 1 year old we will need to almost make a crib out of a bunk for, and a 4 year old i want to just make sure she cant roll out. Any ideas would be appreciated.
bc13 is offline   Reply With Quote
Old 01-25-2016, 10:05 PM   #2
asquared's Avatar
You can use a side rail that slides under the mattress but you will want additional padding on the bed so they don't feel the metal bars. You can create a roll on the side for the 4 yr old using a pool noodle or pillow but I wouldn't use that for the 1 yr old for fear of suffocating themself.
<a href=http://i62.tinypic.com/28rp645.jpg target=_blank>http://i62.tinypic.com/28rp645.jpg</a>
2014 Sabre 34REQS-6
asquared is offline   Reply With Quote
Old 01-25-2016, 10:08 PM   #3
asquared's Avatar
I just came across this but I would check the width measurements.
2014 Sabre 34REQS-6
Old 01-25-2016, 10:11 PM   #4
Thanks for the tip asquared but it dont think any of those will be wide enough.
Old 01-25-2016, 10:13 PM   #5
asquared's Avatar
Sorry wrong link. Try this tuckaire toddler bed
2014 Sabre 34REQS-6
Old 01-25-2016, 10:20 PM   #6
That would work for the 4 year old i think but i will probably just try the pool noodle thing for her. 1 year old would just crawl out of that. Thinking i may have to build something to stop him.
Old 01-25-2016, 10:22 PM   #7
Fulltime family RVer
For the 1 year old, use a pack and play. Losing the floor space sucks, but it's safer. OR, literally do what you said and make a custom crib out of the bunks.
For the 4 year old- either the pool noodle, or IKEA has an inexpensive clamp on rail. We use it for our 3 year old.
Old 01-25-2016, 10:26 PM   #8
Kenny kustom's Avatar
I took a couple boards, and shelf brackets. Stained the boards to match, screwed one set down, and put the other on clips, to be remove able.
2016 Sabre 36QBOK
2015 Ram 3500 CUMMINS
2017 Dynamax Isata 4
Old 01-25-2016, 10:29 PM   #9
yeah we used a pack and play last year and it did suck. Now we have a camper with 4 bunks in the back and we were hoping to get away from that
Old 01-25-2016, 11:56 PM   #10
In the bunkhouse, we set it up and could leave it there. But occasionally had guests where it had to be setup in our living room - we would set it up and break it down each day (and for naps).
I'd rather have a safe sleeping environment for the baby than anything else.
I did explore building a crib. One of my ideas was to buy an IKEA one and modify it to fit our space.
Old 04-09-2016, 08:40 PM   #11
Pool noodle under the sheet for the older one, they also make mesh rail thingies that go under the mattress that might fit your space. Our bunks have smaller entrances and I use one for my 16mo
2015 Cherokee Wolf Pup 16BHS
'94 Ford F350
Ledzeppelin72885 is offline   Reply With Quote
Old 06-04-2016, 06:51 PM   #12
ablarson's Avatar
We use these and love them. 3yo and a 5yo, no issues.
http://m.toysrus.com/product/index.j...uctId=37646236
Newbie
2 RV Trips to date
19 States
2016 Dynamax Force HD
ablarson is offline   Reply With Quote
Old 06-05-2016, 02:17 PM   #13
Thanks for all the tips guys. We are using the pool noodle for the 4 year old and we just fit our 1 year olds whole pack and play into his bunk. All is working well so far.
