Old 04-07-2013, 08:47 PM   #1
OL Creeker's Avatar
King pin stabilizer
For all you 5er owners: what do you think of the tripod, king pin stabilizer?
Alan, Kathy & Cooper the camping cat
2014 Cedar Creek, 36CKTS
2013 GMC 2500 Denali
Duramax/Allison
Full timers since 5/30/2013
OL Creeker is offline   Reply With Quote
Old 04-07-2013, 08:56 PM   #2
QCCowboy's Avatar
Used one on our last 5er and it worked great. Really took the wobble out. Our new 5er has the JT StrongArm stabilizer bars so I am really waiting until our first out to see if we will need the tripod or not. So far from everything else I have read on this forum, the answer is going to be no. If that is the case, one lest thing to carry in the back of the truck and setup.....
Jack of all trades - Master of none
2012 F350 CC DRW - 6.7L PSD
2014 Sabre 36QBOK
QCCowboy is offline   Reply With Quote
Old 04-07-2013, 09:00 PM   #3
B47
Do a search here for opinions of the pros and cons of these things. Plentry of input.
Old 04-07-2013, 09:46 PM   #4
We've got the JT StrongArm's front and rear. They work very well.
Old 04-07-2013, 10:15 PM   #5
JDWeir's Avatar
I use one along with a home made stabilizer. In my mind, it is just one more "hard point" to help keep shake and bounce down.
TV, 2000 Dodge RAM 2500 Quad cab short bed, Cummins 5.9, Edge Comp, Gauges.
5ver, 2011 Palamino Sabre 31 RETS.
JDWeir is offline   Reply With Quote
Old 04-07-2013, 10:26 PM   #6
We had one at first, and it worked very well. But I made a set of stabilizers for the landing gear so I wouldn't have to walk around the king pin tripod. But truthfully, the camper would probably be even better using both.
bakken is offline   Reply With Quote
Old 04-08-2013, 11:54 AM   #7
We use one for our 2012 V-Cross 275 fiver and it take out most of the shake and bounce out. I would recommend one. Good Luck
whj77372 is offline   Reply With Quote
Old 04-08-2013, 11:16 PM   #8
Definitely recommend
Blackgold is offline   Reply With Quote
Old 04-09-2013, 06:58 AM   #9
TURBS's Avatar
http://www.google.com/search?hl=en&r...iw=360&bih=615
Old 05-09-2013, 11:12 PM   #10
how easy are the JT Strong arm'S to install on the front of 2011
sabre 31rets
william C. is offline   Reply With Quote
Old 05-10-2013, 07:35 AM   #11
Camper Less Camping
Cajun Po-Boy's Avatar
sabre 31rets
Easy!
2013 Sabre 32RCTS-6 (sold)
Cajun Po-Boy is offline   Reply With Quote
Old 05-15-2013, 09:28 PM   #12
Hey Thanks .for your reply. As the floor of the storage is extended downward for the spare tire (about 8") right between the front jacks. and the gas line for the out door bbq mounted directly perpendicular towards the rear of the right side of the trailer.was wondeing how you made this an easy install.look forward to hearing from you as I don"t see a solution thanks
Old 05-15-2013, 09:48 PM   #13
Rugged Brown's Avatar
My answer to all this stabilization contraptions used is IMO a waste of valuable camping time to set up. Forget about wasting time setting that up, have a few extra beers and all the shaking is eliminated.
Terry/Bernadette
Lily the Yorkie
2019 Dodge Ram Sport 1500
2019 FR Vibe 28RL
Rugged Brown is offline   Reply With Quote
Old 05-15-2013, 10:01 PM   #14
Lynkage's Avatar
Make your own and do a single from the top of one leg to the bottom of the other.
Here is Turbs' install! http://www.forestriverforums.com/for...albums424.html
Shane & Antoinette
2012 Ford F-450 SuperDuty
2013 Crusader 355BHQ
Lynkage is offline   Reply With Quote
Old 05-16-2013, 07:50 AM   #15
Firefighter969's Avatar
I installed a set of JT Strong Arms and love them took all of the shaking out. Here is a couple of pics. Only took a couple of hours to do and had a few cold ones while working on them.
ID:	30626   Click image for larger version
ID:	30627   Click image for larger version
2000 F250 Superduty CC LB 7.3 4x4
2013 344QB Wildcat
Nights camped 2014 ( 15)
Nights Camped 2015 ( 4 )
Firefighter969 is offline   Reply With Quote
Old 05-20-2013, 10:11 PM   #16
Its a good idea. of course you must be refering to Canadian beer with our 6% or better alc content. Thanks and travel safe (then drink Beer)
Old 05-20-2013, 10:32 PM   #17
Denver, CO
garbonz's Avatar
Winfields work great and no drilling.
Winfield's for Side to side in front
Rotochoks for front to back
Rear electric stabs for side to side and up down in rear.
Very stable.
2017 Fuse 23T
Old 05-21-2013, 06:59 AM   #18
SYE
SYE's Avatar
I used one with my last 5er, and on the new one as well and it helps to take out the wobble, However I recently purchased the JT strongarms and am sold on them as they almost eliminate all of the wobble. If anyone is interested I have my used stablilizer for sale It is a BAL 25035 used less than a year.
Scott & Vicki
2018 Silverado 3500HD Dually 6.6L Duramax/Allison
2018 Columbus 366RL 1492 Edition
Camped 2012 19, 2013 110, 2014 129, 2015 97
2016 93, 2017 79, 2018 84, 2019 47 reserved
SYE is offline   Reply With Quote
