Old 06-19-2019, 06:37 PM   #1
Knife couch problem
I have a knife couch that has a pull out storage area on the bottom. When traveling, the storage area wants to slide out. Any tips on how to prevent it from sliding out. I have been using a wood block wedged under the storage area but would like a better way.
2015 Flagstaff 26VFKS
TV - 2014 F150 Crew Cab 5.0L
WDH - 1,200 Equalizer
txredfish is offline   Reply With Quote
Old 06-19-2019, 07:11 PM   #2
D W
D W's Avatar
Had the same problem. I used a piece of CAMCO Utility Strap and anchored it to the frame. I used a CAMCO snap kit to install a snap to the drawer itself. Cheap fix and it works.
Name:	snap strap.jpg
'04 K3500 Silverado LS with LS3 Connect & Cruise- with Intimidator Mods- Reprogrammed 4L80E
2016 Salem 27RKSS (Pacific Northwest Build)
D W is offline   Reply With Quote
Old 06-22-2019, 10:07 AM   #3
DW,
Good idea. But will not work on mine. The bottom pull out area has about 1/2 padding on front and top. A snap would be difficult and not look the best. Your's doesn't appear to have padding on the bottom pull out.
Old 06-22-2019, 11:35 AM   #4
Get rid of it. I threw my knife couch out. The ever so cheap factor upholstery flaked and peeled off when just five years old. I replaced it with the double power recliners! $1,200 and so comfortable I sleep in them.
Sonic Blue is offline   Reply With Quote
