Old 01-03-2016, 06:41 AM   #1
paulmac's Avatar
Leveling idea - seems simple enough
My wife recently spent some time in the hospital, (she is fine now). While there I noticed these simple leveling devices on the hospital bed itself, and I started to think why is something like this not built into the campers themselves? They could be built in to show level front to back and side to side somewhere on the tongue or on the front of the camper. They would not be curved like they are on the side of the hospital bed but straight so the ball bearing would roll from one side to the other, level would be dead center. Instead having to buy those liquid filed ones that have a bubble that you have to mount somewhere.
paulmac is offline   Reply With Quote
Old 01-03-2016, 06:49 AM   #2
davel1971's Avatar
if they did put them on, they would probably be crooked anyhow. Best off getting what you like and mounting it where it works for you.
David & Lynn
Old 01-03-2016, 08:14 AM   #3
Ambassador
Ken K.'s Avatar
They make these to stick on already. I saw them on amazon.
2016 Ford F250 Crew Cab 6.2 L w/Ride Rite Air Leveling System.
2017 Rockwood Signature Ultra Lite 8335BSS
Ken K. is offline   Reply With Quote
Old 01-03-2016, 08:23 AM   #4
davel1971's Avatar
the type that's on the bed has to be curved, otherwise, if you were 1 degree off level, the ball would be at one end or the other. There are plenty of good ones available now in different styles and sizes.
David & Lynn
Old 01-03-2016, 01:30 PM   #5
GreenImp's Avatar
Send a message via MSN to GreenImp
What you describe does exist in the aftermarket. I have one made by Hopkins (Hoppy) on our trailer. It is designed large so it is visible from the drivers seat via the rear view mirror when parking. I love the idea/theory, but in practice have found that the ball is "sticky" and does not move unless you change the angle several degrees or tap the level. I have jacked one side high enough to remove the wheel/tire for maintenance and had the ball not budge.
It is liquid filled and I have considered mounting it upside down so I can try just using the air bubble instead. I have a feeling it would be far more precise, but probably not as easily seen through the mirror.
'04 GMC Sierra 2500HD, CCSB, D/A, MaxBrake, B&W Companion, Retrax Pro, AR Power Steps
2013 Rockwood 8289WS w/Diamond pkg
1969 Camaro RS/SS Convertible
Dad's old 1968 Empi Imp (recently recovered from under 21 years worth of boxes/dust)
GreenImp is offline   Reply With Quote
Old 01-03-2016, 01:55 PM   #6
I have a large curved level with a metal ball mounted above my propane tanks that I can see from the driver's seat. I also have Anderson levelers that I insert under the tires on the low side. I can then pull forward until the ball is centered. I'm then good for left to right. I then use my electric jack to level front to back with the secondary bubble level. Disconnect and I'm done.
johng4706 is offline   Reply With Quote
Old 01-03-2016, 02:51 PM   #7
dicky1243's Avatar
I have a level that levels side to side with a aprox. 1 " ball and a level on it that gives front to back 25$ at my RV dealer
2006 Gmc
2016 Forestriver Sierra 376 BHOK
Full Timers
Dick,
dicky1243 is offline   Reply With Quote
leveling
