Old 04-04-2016, 11:45 AM   #1
Leveling jack fuse
We have a 2014 puma can anyone tell me where the leveling jack fuse is located? Thanks
tomross is offline   Reply With Quote
Old 04-04-2016, 11:58 AM   #2
Front Jacks on a 5er? Near the battery usually an inline fuse 30amp.
Rear Jacks? In the power panel.
BBQGUY is offline   Reply With Quote
Old 04-04-2016, 12:02 PM   #3
What type system is it? 6 point, 4 point, or just landing gear? If it's a Lippert 6 point in will be in the forward compartment where the hydraulic reservoir is. It will be dangling by 2 wires with a rubber cap on it.
Wumba is offline   Reply With Quote
Old 04-04-2016, 12:10 PM   #4
Thanks, I am new to the RV world and am not sure if it is a 4 point or just landing gear. All that I know is that there are two jacks up front and two in the rear.
Old 04-04-2016, 12:19 PM   #5
Ok, that's a 4 point. 6 point will have 6 jacks. Is it a Lippert system? If so then check the forward compartments. Mine was blowing fuses like crazy and I would up putting an automotive in line relay in it. This way if it popped, it resets in about 3 seconds and no more fuses. It's worked perfectly since that fix. Also, call Lippert if you have any other questions. Customer service is very helpful....574-535-1125
Old 04-04-2016, 06:45 PM   #6
Ok, sounds like a great idea.
fuse, leveling
