Old 02-26-2016, 03:09 PM   #11
I like the Andersons to save space and weight. Worth some $ to me for that. The 'stuff' really accumulates!
2015 Micro Lite 25KS
2006 Suburban 2500 8.1 L
220Chap is offline   Reply With Quote
Old 02-26-2016, 08:00 PM   #12
nowait's Avatar
Agreed!
2008 Silverado EXtCab 6.0 Vortex Max
2010 Forest River Surveyor SV-294
Equalizer 1000 WD/SC hitch
Prodigy Brake Controller
nowait is offline   Reply With Quote
Old 02-27-2016, 08:50 AM   #13
TsnTexas's Avatar
Lots of great info here, thanks! Looks like the Anderson system works well and is also a space saver. I'm assuming that cutting the one means taking off just enough on each end, but not so much on the thin one that the tire will push it instead of rolling onto it.
TsnTexas is offline   Reply With Quote
Old 02-27-2016, 09:11 AM   #14
keeprr's Avatar
Cut the thin end only. It will not push when you pull up on it. I believe there is info on Anderson site on how to cut.
2016 Open Range Light 297RLS Fifth Wheel
2015 GMC 2500HD 6.6L Duramax
Days Camped. 2015: 17
Days Camped 2016: 58
keeprr is offline   Reply With Quote
Old 02-27-2016, 09:34 AM   #15
CaptnJohn's Avatar
Best $$ ever spent was last Dec when I bought a new 5er with auto-level. Push a button and bingo ~~ done. Will never be without it again. Had a factory install.
Old 02-27-2016, 10:57 AM   #16
TsnTexas's Avatar
Ok, found the link for this:
http://www.andersenhitches.com/uploa...%20details.pdf
Old 02-27-2016, 11:00 AM   #17
TsnTexas's Avatar
No doubt that would be the cadillac of systems
Old 02-29-2016, 10:28 PM   #18
I admit, I'm simple minded so I use those plastic leveling blocks but instead of stacking and moving the trailer, I use my bottle jack to lift the axle on the side of the trailer that needs adjustment and place the leveling blocks under the wheels. For me, I find that this works better and faster than moving the trailer forward and/or backwards. When you have two "older" campers with poor hearing, it can be an annoying process!
tosh99 is offline   Reply With Quote
leveling, rockwood
