Old 02-26-2016, 11:05 AM   #1
TsnTexas's Avatar
Leveling the Rockwood 2504s
I think I saw a thread somewhere covering this issue: Because the wheels are so close together, what have 2504s owners found to be the best solution to leveling their camper? Blaylock/Anderson style levelers or just a whole lot of blocks making one long base under both tires? Or something other?
TsnTexas is offline   Reply With Quote
Old 02-26-2016, 11:08 AM   #2
I use Anderson on my same-as-yours 25KS. Cut to fit and works well.
2015 Micro Lite 25KS
2006 Suburban 2500 8.1 L
220Chap is offline   Reply With Quote
Old 02-26-2016, 11:14 AM   #3
TsnTexas's Avatar
Are you able to support both axles with them?
Old 02-26-2016, 11:22 AM   #4
Yes. To save money, I bought one Anderson level and one Rapid Jack. Can use them together to level. I don't need to level very often. I use the Rapid Jack as a trailer jack stand mostly. And of course to be ready to change a flat.
Old 02-26-2016, 12:41 PM   #5
Anders's Avatar
If at all possible I try to lower the center of gravity. Using a small spade/showel to remove some dirt where possible. Can't be done in some places but works very well in others. I wrote a blog post on that.
Cheers,
Anders Campbell River, BC. Canada
Pony: 2017 Dodge 3500 Longhorn 4x4, Quad Cab Chuckwagon: 2011 Rockwood 8265WS
My RV Cookbook now on Amazon! USA or Canada
Travel Blog
Cooking Blog
Anders is offline   Reply With Quote
Old 02-26-2016, 12:51 PM   #6
Canadian Member
I just keep a couple of pressure treated 2x10s in the pickup bed for leveling side-to-side. I like the thought of the Andersen Levelers but I have too much Scottish blood in me to spend over $100 Canadian for 2 of them. I can buy a lot of 2x10s for that price.
2019 Rockwood Signature 8290BS, Reese Revolution pinbox and B&W Patriot 18K hitch
Old 02-26-2016, 01:02 PM   #7
Left Coast
X2
Old 02-26-2016, 02:01 PM   #8
keeprr's Avatar
Anderson leveler blocks. Cut one to fit between wheels and they work great. Level in just a few minutes with no hassles. Just back up till you are level.
keeprr is offline   Reply With Quote
Old 02-26-2016, 02:34 PM   #9
Semperfi24's Avatar
We do whatever needs to be done at that particular site, or a combo of the following:
1) 2'X10" that are about 10" long, making them square
2) lego blocks
3) scraping some dirt from the high side
With the 2"X10"X10" you can put one in front of the front tire of the trailer, and one between the tires, and then pull forward onto them (or back on to them, which ever you need. If that isn't enough, you can then double them up. Put 2 in front of each tire (with the tire already on one, so you are going from 1 to 2 instead of ground to 2) and repeat the process. We have also had to go one level of 2X10 and 1 lego block, etc. As long as you have a few different thicknesses of "blocks", you should be able to work it out. I find the secret is having them short enough that they fit between the tires, so you don't have 4' long boards
_________________________
2018 Rockwood Mini Lite 2504S
2018 Ford F150 Lariat Special Edition 3.5 Ecoboost
Semperfi24 is offline   Reply With Quote
Old 02-26-2016, 02:39 PM   #10
This is how we do it! Youroo!!
Old 02-26-2016, 04:09 PM   #11
I like the Andersons to save space and weight. Worth some $ to me for that. The 'stuff' really accumulates!
Old 02-26-2016, 09:00 PM   #12
nowait's Avatar
Agreed!
2008 Silverado EXtCab 6.0 Vortex Max
2010 Forest River Surveyor SV-294
Equalizer 1000 WD/SC hitch
Prodigy Brake Controller
nowait is offline   Reply With Quote
Old 02-27-2016, 09:50 AM   #13
TsnTexas's Avatar
Lots of great info here, thanks! Looks like the Anderson system works well and is also a space saver. I'm assuming that cutting the one means taking off just enough on each end, but not so much on the thin one that the tire will push it instead of rolling onto it.
Old 02-27-2016, 10:11 AM   #14
keeprr's Avatar
Cut the thin end only. It will not push when you pull up on it. I believe there is info on Anderson site on how to cut.
2016 Open Range Light 297RLS Fifth Wheel
2015 GMC 2500HD 6.6L Duramax
Days Camped. 2015: 17
Days Camped 2016: 58
Old 02-27-2016, 10:34 AM   #15
CaptnJohn's Avatar
Best $$ ever spent was last Dec when I bought a new 5er with auto-level. Push a button and bingo ~~ done. Will never be without it again. Had a factory install.
Old 02-27-2016, 11:57 AM   #16
TsnTexas's Avatar
Ok, found the link for this:
http://www.andersenhitches.com/uploa...%20details.pdf
Old 02-27-2016, 12:00 PM   #17
TsnTexas's Avatar
No doubt that would be the cadillac of systems
Old 02-29-2016, 11:28 PM   #18
I admit, I'm simple minded so I use those plastic leveling blocks but instead of stacking and moving the trailer, I use my bottle jack to lift the axle on the side of the trailer that needs adjustment and place the leveling blocks under the wheels. For me, I find that this works better and faster than moving the trailer forward and/or backwards. When you have two "older" campers with poor hearing, it can be an annoying process!
tosh99 is offline   Reply With Quote
leveling, rockwood
