Old 03-19-2015, 04:17 PM   #21
Just spit balling here but wouldn't deploying stabs before slides are out put unwanted weight on stabs after slides are deployed? They are stabilizers and not jacks, right?
breakaway is offline   Reply With Quote
Old 03-19-2015, 04:51 PM   #22
I put my stabs down first (first trip) and then couldn't close the bathroom door because the frame was flexing. I figured 'this can't be good' so I haven't done that again. I have two slides on the same side and they weigh a lot. From that day on I always put stabs down after slides and put stabs up before the slides go in.
2010 F250 5.4L 3.73
2011 Flagstaff 831FKBSS
Equal-i-zer 4pt 12K
2010 F250 4X4 5.4L 3.73 LS
EQUALIZER E4 1200/12000
Old 03-20-2015, 01:12 PM   #23
I've tried it both ways and still don't have a good answer. The stabs on my trailer are power and have a single switch on the front and rear. When one side comes down and touches the ground, it stops and the other leg continues to come down until both are on the ground stabilizing the trailer. Now, this makes me think that the two legs are floating and not independently attached. If this is correct, then even if I put the stabs down before putting out the slides, when the slides do go out, the trailer will adjust so that the leg on the slide side does not get excessive weight put on it. Both legs will be down stabilizing the trailer but the weight will be evenly balanced side to side (slides in or out).
Does anybody have any thoughts on this subject?
Gary Hadden is offline   Reply With Quote
leveling, slide, slide out
