Old 08-30-2013, 11:32 AM   #1
2011 Forest River Stealth
rwtdct's Avatar
Licence Plate Hinge
I don't know how many have experienced pulling into a parking lot, gas station etc and bent there licence plate from dragging on the ground.. My licence plate is mounted to my rear bumper and also hangs below the bumper. It has been bent a couple times.
Anyways, I just installed a spring hinged licence plate holder. I am hoping this will do the job. I just hope I don't have to back-up when its rubbing the ground, the hinge only springs one way.
Spring hinge licence plate holder.
2011 Stealth CSFCK3214
2003 Ford F250 Crew Cab 4X4 7.3
2011 Polaris RZR 4
rwtdct is offline   Reply With Quote
Old 08-30-2013, 11:44 AM   #2
Looks good. But one question: does CA not require that the license plate is illuminated?
Flying dutchman is offline   Reply With Quote
Old 08-30-2013, 11:45 AM   #3
B47
Isn't there room on the bumper to mount the plate up an inch or so so the plate doesn't extend below the bumper?
I didn't see any plate illumantion light to deal with.
Old 08-30-2013, 11:55 AM   #4
rwtdct's Avatar
If you look just to the right, that is the light to the licence plate. I could have raised the licence plate up to the rear door hinges but it would have still had 2 to 3 in. hanging below the bumper. If the licence plate would have fit between the rear door hinges, I could have raised it up and been fine. I could have moved the licence plat to another location but then i would have had to move the licence plate light. This was an easy fix, drilled 2 holes mounted and done. Approx 10 min. Also this trailer did not come with under skids.
2011 Polaris RZR 4
Old 08-30-2013, 12:01 PM   #5
B47
If you look just to the right, that is the light to the licence plate. I could have raised the licence plate up to the rear door hinges but it would have still had 2 to 3 in. hanging below the bumper. Also this trailer did not come with skids.
OK - I didn't recognize the light holder at first look. So I guess you had to mount the plate over the right side hinge,which doesn't seem to be a problem.
Seems like the trailer manufacturer could have come up with a better design to start with.
Old 09-02-2013, 10:30 AM   #6
Stg1's Avatar
I don't have the dragging problem, but the dealership mounted our plate with commercial grade zip ties. No bolt rusting or corrosion and no problem changing plates when they expire. You can do the same thing with regular zip ties. The plate doesn't weigh that much and you only get a small amount of swing in the wind.
Steve and Marlene and 2 Furry Kids. LB (Maltese) Rocky (Border Terrier)
2013 Coachmen Catalina 25RKS 2006 Nissan Titan Crew Cab
Stg1 is offline   Reply With Quote
Old 09-21-2013, 11:00 PM   #7
What happens when you back into a steep driveway? My boat trailer has that plastic flexible plate hanger but the plate still takes a beating.
tosh99 is offline   Reply With Quote
Old 09-21-2013, 11:24 PM   #8
phat phrog stunt crew
i see holes in the bottom of the plate, and what looks like a bit of space to attach a bungee cord to on the small black spring. a simple 1 dollar fix if need be. install and remove as needed.
dwaynerz is offline   Reply With Quote
Old 09-22-2013, 12:26 AM   #9
I think I would move the lic plate up to the bottom of the door and use spacers to space the lic plate out enough to clear the hinge.
09grizzly1
2012 Palomino Ultralite T245
2004 F250 Supercab 5.4L
09 Grizzly 700 EPS
09grizzly1 is offline   Reply With Quote
Old 09-22-2013, 09:32 PM   #10
i think that would be a lot of spacers. maybe move plate up to bottom holes, move bracket up and then let the door fold plate/hinged bracket down. rotate light to shine more on plate, or just call light good and follow the intention if not the letter of the law.
