Old 08-25-2014, 03:04 PM   #1
Lifting Jack Problem
Three times in the past month my Leveling jacks will not work. The lights all flash when the key is turned on but when you press the Auto button it doesn't light and the jacks won't work. After resetting the brakes 3-4 times I gave up. Went back 1/2 hour later and they worked.
Had the problem again today and it's been an hour and still won't work. Followed the instructions in the manual but no luck.
Anyone have any ideas?
Flnomad is offline   Reply With Quote
Old 08-26-2014, 02:23 AM   #2
qwkzotc's Avatar
Is it possible that the wire that powers the jacks gets the power from something else upstream? For instance, they may have tapped the power for the jacks from the power to the porch light so that it only works when the porch light is on. Extreme example but think about what else you turned on or off in the 1/2 hour between attempts. Happened to me with something else, but same deal. Another thought is the loose wire scenario, even tougher to track down.
Dan
qwkzotc is offline   Reply With Quote
Old 08-26-2014, 08:31 AM   #3
Thanks I will consider that. Thirty minutes after I posted I tried the jacks again and they worked fine. Strange!
