06-20-2011, 08:30 PM
Lighting Magic Chef Oven
Three times camping and I still can't find the place to put the match to light our oven. I have been using wooden matches. Do I need a long tip lighter? The spark ingiter works fine on the top burners. Any suggestions?
06-20-2011, 09:33 PM
Moderator
Get the manuel out and try to see where the directions are referring. If you have the same manuel as I then you will need to turn the book a bit to get the drawing facing in the correct direction. Use a flashlight in the oven to see the placement of the pilot light is located. When you are ready hold the oven knob in while you light the pilot light. Keep holding the knob for a little longer - maybe 20 seconds if you haven't use the oven for a while.
I use one of those long hangle lighters instead of matches.
Great choice for "Living within my means" and camping for one... 2011 Salem Cruise Lite 20RBXL & 2011 Toyota Tundra Dbl Cab 16 Trips / 43 Nights / 1204 Miles
06-20-2011, 09:34 PM
Trouble lighting the oven.
I always use the butane SCRIPTO lighter for the pilot light in the oven. Requires you to stand on your head, hold a flashlight, hold in the oven "START TO LIGHT" knob, all at the same time while holding the lighter lit
to the pilot. While all this is going, D/W hollering "FOR GODS SAKE, DON'T
BLOW US UP", of course my dear Boykin Spaniel thinks it is time for a good face licking.
Now that is not in the instruction book, but should be!
Sid & HRH- Daisy the Boykin.
2011 ROCKWOOD 8285 WS
2005 F-150 SUPERCREW
SUPER GLIDE HITCH
06-20-2011, 10:34 PM
 Now that is funny. But not too far from the truth. If you look closely near the back of the burner you will see a hood about 1 inch square with what looks like an orifice. That is the pilot assembly. While pushing in on the burner control set to pilot you use a gas match and hold the flame in there. You may or may not see a poof as the gas ignites. Continue holding the match there for about 30 seconds. Remove the gas match and check to be sure the pilot flame is still burning. Hold for an additional 30 seconds or so and let go of the knob. If the pilot goes out, repeat the process. I have found it best to actually turn the t'stat to 250 or so and let the burner actually light. Turn burner back to pilot and you are set for the weekend.
06-21-2011, 12:28 AM
I bought the DW a pair of those rubber knee pads from Lowes to help her with this task, the rest.............. is not in the instruction book and shouldn't be!
Nigel & Bev
Brit Driver & Canadian Naviguesser
2011 Rockwood Signature Ultra Lite 8280ws
2011 Dodge Ram 3500 SB Crew 4x4 Diesel
Nights camping 2011 ...181...
06-21-2011, 05:50 AM
Light the oven.
Knee pads, now that is not a bad idea. How in the world did you get her so well trained? I bet she opens and brings your beer to you while she is trying to light the oven? Is your D/W Bulgarian?
Brit, did you get any damage to the 5ver from the two blow outs you had?
SUPER GLIDE HITCH
06-21-2011, 10:26 AM
All of the above advice, plus - until you get the hang of it, make it a two person job. That way you have one hand for the flashlite, one hand for the butane lighter, one hand for the oven control knob and one hand to fend off the poodle !
...VTX-AL
06-21-2011, 10:57 AM
Yes but only to the thin Ali sheet behind the rear tire it bent it upwards but did not effect the exterior.
Nigel & Bev
06-28-2011, 04:18 PM
So that's how you light it huh! I always turned the knob waited about 10 minutes and struck the match from the picnic table! Got lit everytime. And the oven too! My wife's idea of a pilot light is turning the key in the ignition and finding a good restaurant.
11-13-2011, 09:22 AM
 I haven't been to this thread in quite a while. Thanks to everyone because my wife and I just had our good laugh for the day. Foolish me to think lighting the stove's pilot light would be simple, but like everything in life, things are easier if you know what are doing. Thanks again.
| Thread Tools |
| Display Modes |
» Recent Threads |
» Online Users: 592 |
| 118 members and 474 guests |
| 2011sv264, 4bnabird, 4Jeeperz, Adony, ayotte, B47, BAJohnny, bayouboys, bikeman911, bikendan, bka4tcu, bob213, Bob_Loblaw, boubou, Buffalohunter, bush, buzzmonster, caper, carsonizik3, cgreen1509, chevy02, cllecr, crawford, cyclepuck, dasimser, daw592, ddemme, DeeMax, dezolen, donh, donn, Drmstx62, Dutch & Di, fast murray, Fire Instructor, forensicdeac, FreedomTracker, gb73071, gimp425, GlacierGus, greran, h20ski, Happy Campers 79, hark582, Hilgy, hjmiberry, Iggy, itat, Itsthetwoofus, J McClure, J R, JamesR, jasni, jimandjoyhamel, JJL, johnthecamper, Jsroberts5, kalyna, Kellahut1, Kirby, KRS, kwjeepxj, Mad4sax, manvel, Margaret, Marsh707, miatared, michel, miked11272, MikeT, Mnflyboy, MrAllen, mtfd515, mtnguy, ncgrl1, newtsx3, NO3putt, nowait, ohiobill, partime, patov6, Pawpod, peaeye, Phil1, PHS79, punkaccountant, rgfenner, RJHuser, rkswyo, rmason8092, RockyMtnHigh, Rsgtivr6, sandys, Sbbs2228, sbond, Sg6923, showtime0022, silverwing, SinkorSwim, sjones7246, Smithee, snackage, Stedman1, steeleshark2, Steve7575, Swinks, Tekknogeek, tentcamper1, Terier, thom01, Tincup13, tking1866, troyt, trudinator, VinceU, vp22er, WestCoastRV'er, Westernflyer |
| Most users ever online was 1,025, Today at 01:04 PM. |
