Not sure which issue is the main culprit but the leaking solenoid valve does give cause for concern. You didn't have to open the solenoid with a hex wrench, all you had to do was hook a jumper wire from the positive post of the battery to the solenoid that you wanted to function. You can see the wire connections at the top of the solenoid valves.
2016 F350 CC Dually Powerstroke 4x4
2014 Cedar Creek 34RLSA w/Level Up
2007 HD Ultra Classic 103
USS Pyro AE-24 WestPac MM2 '71-'75
