Old 05-06-2011, 07:25 PM   #1
Location: No longer own a Forest River product, but enjoy the info on this site
Lost --- W/D hitch part
So I lost the bar that is used to raise the cam on a Reese Pro Series weight distribution hitch. I don't know what the technical name for this part. Its the hollow metal pipe... Does anyone have any ideas on what to use instead of the "pipe" that comes from Reese??? Is there a source for this part??? ( I checked the reese website and nada )
In a pinch, I used the hallow end of the handle for my floor jack.
Thanks for your ideas
Darren
teamgl is offline   Reply With Quote
Old 05-06-2011, 07:38 PM   #2
kalik282's Avatar
Darren,
I used to use a short piece of EMT (Electrical conduit) for mine. Worked fine. However, if, after you hitch to your TV ball, you jack your camper tongue jack back up, lifting the TV at the same time, you will find you don't even need the pipe. I have been doing mine by hand for 3+ years. Some searching here on the forum will result in many posts about this.
John
John & Nicole
2004 Ford Excursion 6.0L 4x4
2011 Flagstaff 831FKBSS
Nights Camped: '06=122 '07=12 '08=18 '09=10 '10=18 '11=28 '12=16
kalik282 is offline   Reply With Quote
Old 05-06-2011, 07:49 PM   #3
frankm's Avatar
You may find what you are looking for here, Reese Accessories and Parts | etrailer.com.
I think the part you need is sold in conjunction with the brackets and seems somewhat pricey if all you need is the pipe. John's approach may be all you need.
Good luck!
Frank & Rita M
2016 Ford F-150 XLT Ecoboost
2017 Rockwood 2703WS
frankm is online now   Reply With Quote
Old 05-06-2011, 09:36 PM   #4
BOBFIDY's Avatar
How about going to your local Lowes or Home Depot and buying a piece of 1/2" black gas pipe about 12 to 18" long? Should work perfectly.
2011 FORD F350 CREW CAB DUALLY DIESEL 4x2
2010 Salem LA 292FKDS
One of the Original 14 F.R.O.G.s
1st, 2nd, and 3rd INTERNATIONAL F.R.O.G. RALLY Branson. MO.
1st, 2nd, and 4th INTERNATIONAL RALLY Goshen, IN.
BOBFIDY is offline   Reply With Quote
Old 05-07-2011, 01:05 AM   #5
I just replaced the same thing. I got a replacement form here Curt Weight Distribution Lift Handle Replacement - 17112 - Heavy Duty Hitches at Trailer Hitches. $12.99 plus shipping.
Weebdog is offline   Reply With Quote
