Old 01-22-2016, 06:29 PM   #1
Low Water Pressure
We have a DR 3170DS, and are camped at a nice location, but at the end of the park. Water pressure is a bit low connected to city water. We haven't used our on board water tank, but a neighbor suggested that we fill it, turn on the water pump and it will augment the shower pressure combined with the city water. Is this so? Any problem leaving the water pump on along with the city water? Will the water pump sense that the city water is on and automatically shut off the water pump? Any enlightenment to this situation is appreciated. Thanks.
Linda
LTRVing is offline   Reply With Quote
Old 01-22-2016, 06:33 PM   #2
Who Dares, Wins
doc73's Avatar
Not sure about leaving the City water hooked up and using the pump at the same time. A check valve will keep the city water fro,m back flushing the tank. I have filled my tank and used that for pressure when in a low city water situation.
2015 ChevyHD D-Max
2018 Artic Wolf 315tbh8
doc73 is offline   Reply With Quote
Old 01-22-2016, 06:36 PM   #3
Thanks, so use the on board water and pump while showering with city turned off?
Linda
Old 01-22-2016, 06:37 PM   #4
Left Coast
The pump will sense water pressure from the lines being full and shut off......was on well at at a campground and turned pump on to supplemen press. as the pump had a higher sett'n....worked for me...
Old 01-22-2016, 06:46 PM   #5
If the city W/P is that Low fill your Tank and use your Pump! You gain Nothing by leaving the City water connected! You could have a Pressure tank installed in your Sunseeker 3-5 Gal. and on Pump you would have smooth/even water pressure just like in a House! And the pump wont come on/off every time you use your F/W system! Youroo!!
Old 01-22-2016, 06:53 PM   #6
Thanks to all! The DW will be happy.
Linda
Old 01-23-2016, 09:50 AM   #7
A32Deuce's Avatar
We were in a CG in WV last year like that, filled FW tank and used both. No problem. Like using Electric/ Gas same time for shower!
Sent from my DROID4 using Tapatalk
A32Deuce is online now   Reply With Quote
pressure, water
