Old 05-31-2013, 11:54 AM   #1
TURBS's Avatar
Maybe this will help with "how big of generator do I need" sticky?
Common 120v draws.
A/c 12-16 amps
Converter 1-8 amps
Microwave 8-13 amps
Fridge "electric" 5-8 amps
Water heater "electric" 9-13 amps
Common 12v draws
Furnace 10-12 amps
Fridge on gas 1.5-2 amps
Water pump 4 amps
Co detector 1 amp
Old 05-31-2013, 02:10 PM   #2
Thanks Turbs
Good to know what each unit draws.
Ken & Janet
'07.5 GMC 2500 D/A CC/SB
'09 SABRE 31RETS-6
wingriders is offline   Reply With Quote
Old 05-31-2013, 08:14 PM   #3
TURBS's Avatar
Originally Posted by wingriders View Post
Thanks Turbs
Your welcome!
Old 06-10-2013, 04:35 PM   #4
Paul & Sheri
pwb01's Avatar
When you're doing the numbers you must keep this in mind.
The advertised rating in watts for generators are peak watts that it can handle. An electric motor will surge to much a higher draw than rated for a few seconds and that's what the rating is taking into account on generators. They can surge to the higer number for a few seconds.
For example: The Honda EU2000 is rated at 2000 watts or 16 amps. It will only handle 1600 watts for continuous operation so that's the number you want to use. That's about 13 amps. An air conditioner can draw 20 amps continually and surge to 22 or 23 when the compressor starts. Other electric motors to consider; pumps, fans, furnace fans, etc
2012 F150 F/X 4, 6cyl EcoBoost with Max tow pkg
2013 Rockwood 8280WS 5th wheel
2006 Sunline T1950
2004 T@B T-16
pwb01 is offline   Reply With Quote
