Old 03-27-2017, 10:34 PM   #21
tuckerdog1's Avatar
Originally Posted by jtesta1 View Post
Electronic foam cutter available at Amazon.com. has 1001 uses and who couldn't use another tool.
If this is one of those wire cutters that heat up, I have one. Okay on regular foam. Was of no use on the memory foam.
Tuckerdog1
2016 RAM 2500 Cummins SLT Lone Star 4X4 LB
2016 Windjammer 3029W Platinum
I'm not an expert. But I play one on the internet.
You live & learn or you don't live long.
If you don't punish your children, life will.
tuckerdog1 is offline   Reply With Quote
Old 03-27-2017, 11:51 PM   #22
drelec's Avatar
Made a queen memory foam a short queen today by cutting off 5 inches using a fish filet knife with 8 inch blade. Heated blade with propane torch and it cut like butter! Don't breath fumes.
Prime Time Manf. Crusader 270RET 2012
Ford F150 5.4L B&W Companion Hitch
updated to Andersen Aluminum Ultimate Hitch 2017
drelec is offline   Reply With Quote
Old 03-28-2017, 10:25 AM   #23
As others have suggested, the best way to cut foam is with an electric carving knife. Done it many times and the cut is very easy and precise.
bobm253 is offline   Reply With Quote
Old 03-29-2017, 01:35 PM   #24
mac.dblues's Avatar
Not sure what the hang up is on making it pretty. I'm a first born/perfectionist. I cut the foot of our 3" topper with cooling beads down with a box cutter. I took two or three passes that weren't quite all even. Then I took the cut end and turned it to the headboard. Even when the bed is not made, you won't know it's cut to fit...
2017 Cherokee Grey Wolf 26RL Dragged around by a 2004 Ford F-150 FX4 5.4L
2018 Nights Camped 05 : 35 total booked
2017 Nights Camped 37
2016 Nights Camped 23 (3 in popup)
Laissez les bons temps rouler!
mac.dblues is offline   Reply With Quote
Old 03-30-2017, 08:37 AM   #25
CarolinaGirl's Avatar
Originally Posted by Happy Camper 2715 View Post
The best way I have found to cut it was using an electric carving knife, The same one you use for Thanksgiving Turkey. you just have to be careful to keep the knife vertical, or the edge won't be even.
I did the exact same thing. It isn't the prettiest of jobs, but I really don't care. It is always covered by the bedding anyway.
No Longer Newbies
2016 Trips:16 Nights:41
2015 Trips:13 Nights:29
2014 Trips:13 Nights:31
CarolinaGirl is offline   Reply With Quote
Old 06-15-2017, 01:08 AM   #26
Didn't have to cut ours. It fit right out of the box. 4 inch from Walmart. We're happy. We bought one for our house bed from Sams. Also 4 inch. We like it.
Librarianwhs is offline   Reply With Quote
