Old 08-17-2011, 02:22 PM   #11
The Old Man
Willis's Avatar
I will add (slightly off-topic) that moth balls definitely keep the wasps and hornets away. I put some in the outside vent of the frig and hung some under the cover of the propane tanks and no more hornets!
I wonder if that would work for mice too? I had really bad mice infestation this summer.
2010 Flagstaff 829RGSS
Still to go: AK, NL, NT, NU, YT
Willis is offline   Reply With Quote
Old 08-17-2011, 02:24 PM   #12
caper's Avatar
Is there a bird feeder close to your TT? We use to have a problem with mice when one of the campers near us had a bird feeder. The seeds on the ground attracted the mice to the area. Since the feeder is gone we have not had a problem with mice. Have heard that moth balls around the TT will keep mice away. Do not know if it works or only a urban myth.
Terry and Janet
2008 3001W Windjammer
2007 Ford F150
Old 08-17-2011, 02:41 PM   #13
bounce sheets
2011 Ram Laramie
2010 Rockwood 8319ss
2010 Polaris sportman 300(wife's)
2005 Polaris sportman 500HO (mine)
trailraider is offline   Reply With Quote
Old 08-17-2011, 04:29 PM   #14
jimh's Avatar
good to know. i've almost been stung several times. wasp love those places and some i didn't expect.
jimh is offline   Reply With Quote
Old 08-18-2011, 06:22 AM   #15
hoovercab's Avatar
I hear this one and tried, no luck they still in around and shreadded the bounce sheets for their nest. I was told to only us this brand.
Sheldon & Kathi Hartwell
Dexter and Ryley our beagles
2003 Forest River Flaggstaff 829 BHSS
2001 Lincoln Navigator All Wheel drive
hoovercab is offline   Reply With Quote
Old 08-18-2011, 12:50 PM   #16
Villa Estate 392FLFB
The_Stuff's Avatar
Originally Posted by trailraider View Post
bounce sheets
myth. ive seen nests made of the stuff.
One state/province at a time!
The_Stuff is offline   Reply With Quote
Old 08-18-2011, 01:59 PM   #17
hoovercab's Avatar
Bird Feeders
No, no bird feeders. Just 2 beagles who do catch them from time to time.
Old 08-18-2011, 02:04 PM   #18
hoovercab's Avatar
Thumbs down Bounce
bounce sheets
Sorry did not work, they used it to a build nest, and yes I did use bounce orignal scent. Someone had given me this one. thank you for the advice I will try anything to get rid of them.
Old 08-18-2011, 02:56 PM   #19
Wintergreen oil also works! Just put some on a cottonball! ( make sure you put the cottonball on a pc of foil or something like that, because that stuff will eat through plastic, so no telling what else it will eat through!!). Good Luck!
Oubie Jr is offline   Reply With Quote
Old 08-18-2011, 03:17 PM   #20
RV Newbie
buzzards27's Avatar
I found an opening I bet most people have overlooked. The outside refrig vents. If you look up at the outer plastic panel there are several rows with dozens of mice size openings. My fix was to hot glue pieces of course plastic filter fabric, similar to a pond filter over the inside of the holes. Takes a little time and calculations to make it work because it had to be folded. Have not seen a mouse in the house since.
2005 FR Lexington 210 6.0L 8500 miles
2007 2500 Silverado Ext. Cab, 6.5' bed 5.7L
2010 Ford Fusion Hybrid
1963 Ford 861 5 speed with loader
1958 Ford 800 Select-O-Speed (parts tractor)
buzzards27 is offline   Reply With Quote
