Old 07-06-2015, 07:06 PM   #1
xman123's Avatar
Mice Prevention
does anyone have a tried and true method that works to keep mice out of your motorhome? My wife Hates Mices to pieces lol
OK question Time...
2016 Georgetown 335ds
Larry and Judy Crossman
Lancaster NY
xman123 is offline   Reply With Quote
Old 07-08-2015, 01:08 PM   #2
xman123's Avatar
i see an ad for peppermint oil..any one ever use it and does it work?
OK question Time...
Lancaster NY
Old 07-08-2015, 01:21 PM   #3
I've used it along with dryer sheets for 3 years and have not have a problem. I can say for sure what works and what does not but I will keep doing this until I have a problem. I have also sealed up the RV to the best of my ability and try to get out all food during storage.
2015 Rockwood Roo 23IKSS
2015 GMC Sierra 1500
Archicamper is offline   Reply With Quote
Old 07-08-2015, 02:23 PM   #4
xman123's Avatar
yeah i used dryer sheets...the mice made nice nests out of them lol
OK question Time...
Lancaster NY
Old 07-08-2015, 02:41 PM   #5
scootingranny's Avatar
We have only had our unit since March but we got some of these Robot Check
2015 Coachmen Chaparral 360 IBL
2014 Ram 3500 Turbo Diesel 6.7 4wd Crew Cab Dually
scootingranny is offline   Reply With Quote
Old 07-12-2015, 07:54 PM   #6
I'm trying some WalMart All Purpose cleaner with bleach. A friend has had good results with it, spraying the tires and ground around them as well as areas of the frame where mice can enter the unit through the frame and holes for wiring and plumbing.
wyoman is offline   Reply With Quote
Old 07-12-2015, 08:02 PM   #7
Cab Fresh is THE!!! best. But not available in Canada ( have to sneek it in )
2014 Forester 3051s
2016 Nissan Pathfinder SL
2012 Sonic toad
wana65stang is offline   Reply With Quote
Old 07-14-2015, 10:14 AM   #8
My WalMart cleaner worked well for the mice. �� I went into town and was lucky to find some Fresh Cab and put it close to where I think they're coming in under the shower. But also found a new hole and plugged it with tin foil (no steel wool with me). Got a good nights sleep with no visitors! I'll have to figure out if it's the Fresh Cab or the tin foil that did the trick.
Old 07-16-2015, 02:17 PM   #9
We purchased some peppermint oil and it isn't working. We have tried moth balls and this peppermint oil. They seem to still get in. We have traps set and catch a few with them. I still looking for a tried and true way to rid our Wildwood Lodge of mice!
aablom is offline   Reply With Quote
Old 07-16-2015, 02:41 PM   #10
Flybob's Avatar
The peppermint works, but you need to get "Essential oil of Peppermint" not common peppermint oil. This can be found at health and holistic stores. Put 4-5 drops on a few cotton balls in an old glass or coffee mug. Do not get it on anything it will damage paint and plastic. Replenish when the scent gets weak. I have used in my RVs for years and no mice or spiders despite mice in the garage right next to it.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
vent
