Old 01-21-2013, 02:08 PM   #1
Minimize lawn Damage while parking-HELP!
When parking our 5 vr on the pad next to the house, I have to back over a patch of lawn which I sometimes will tear up with the front truck tires as I maneuver into place. Other than adding more concrete, I'm looking for a way to minimize the lawn damage.
I've seen landscaping companies use something like these which would probably do the trick but I think they would be heavy to move around and store and I would need like 4-4x8 sheets (>$$).
I also thought about buying a bunch of small rubber door mats and liberally distribute them over the targeted area...but...
What I'm really hoping for is that there will be someone here who has already figured this out or maybe would have a better suggestion.
btw. prior to the 5ver, I've sucessfully parked a 30 TT on the same pad for many years, but the TV was a SUV at that time.
Cathy & Jeff
Midland, Michigan
2020 Cedar Creek 34IK / 2019 Ram3500 CID
SimchaSabre is offline   Reply With Quote
Old 01-21-2013, 03:05 PM   #2
phat phrog stunt crew
some pieces of plywood maybe. would spread the load out more. have seen them used under cement truck tires to minimize ruts in the yard. and since they are flat, they can be stored on the garage floor and your truck will park over the top of them if using full sheets.
dwaynerz is offline   Reply With Quote
Old 01-21-2013, 03:33 PM   #3
coupevillefish's Avatar
Instead of just laying down concrete, you might consider the porus blocks that will let the grass grow through. They give support while leaving the area green and able to absorb rain water. I have seen them used succesfully in a couple of local community parking areas where "green" is a priority. (Think Washington rain:-)
coupevillefish is online now   Reply With Quote
Old 01-21-2013, 03:36 PM   #4
I have sections of used conveyor belts that I roll out. They can be stored either rolled up or placed flat on the garage floor.
Pa-cj5 is offline   Reply With Quote
Old 01-21-2013, 03:41 PM   #5
Why not go to a large vacant parking lot and mark out an area like you have to park on at home and practice parking it? If you could park a tt on it without tearing up the yard, it should be possible to put the 5er in it also.
Old 01-21-2013, 08:32 PM   #6
Oklahoma Proud
MillerTime's Avatar
Well Simcha I was going to recomend some of those rubber mats that are used in construction, but I clicked on your link and there they were! Only other thing I can think of is I believe tractor supply or something like them, carry stall mats that are about 1" thick and I think they are about 4'x6'- I had an add that had them in it, but I think I threw it out yestetday.
Old 01-21-2013, 10:14 PM   #7
i question too how you could back a tt into the same spot and not tear up the yard. might be time to invest in a concrete apron to tie the two areas together. or, stock up on dirt and grass seed
Old 01-21-2013, 10:41 PM   #8
Oklahoma Proud
MillerTime's Avatar
Hey you guys are forgetting that you have to turn your truck much, much more to get the trailer to react on a 5er/gooseneck. You can back a 5er trailer down the tightest winding path, but you will need a lot of "wiggle" room for the truck.
- That's why he need our advise!
Old 01-21-2013, 11:26 PM   #9
fast murray's Avatar
Eventually you'll probably wish you had some sort of surface other than grass in that area. Our pad is packed gravel and is accessed off our gravel driveway. It's a pretty tough surface. I have to back down the driveway and around turn 90* to get next to the shed which doesn't always happen on the first try.
2004 Wildcat 28BH
2012 Ram 2500 CCSB 6.7CTD
fast murray is offline   Reply With Quote
Old 01-24-2013, 11:34 PM   #10
Capsfloyd's Avatar
What about the ground up rubber they use on play grounds It drains very good , and can be re spread around. ?
2009 Rambox crew cab
2012 831 Flagstaff RKSS
2010 jeep Liberty
2010 Harley Davidson Ultra Classic
Capsfloyd is offline   Reply With Quote
Old 01-25-2013, 06:48 AM   #11
I used 1ft x 1ft flat patio type blocks next to my driveway, on my neighbour's side. They stay there. Some days backing in are better than others I dug out the path then put down stone powder(can't remember the proper name). I have to straighten them every once in a while but they work.
Pipeman is offline   Reply With Quote
Old 01-25-2013, 09:13 AM   #12
I have experienced the exact opposite, the 5er is much easier and takes much less wiggle room for the truck. I just have to react a little faster with the truck or back slower and watch where the trailer is going.
Old 01-25-2013, 09:45 AM   #13
as with oldcoot, i too experienced less "wiggling" when backing a 5vr/gooseneck/semi trailer than i did backing my old tt or any bumper pull type trailer.
Old 01-25-2013, 10:21 AM   #14
Oklahoma Proud
MillerTime's Avatar
Well I guess the longer the trailer or the further back the axles on 5ers the more movement needed from the tv- look at a semi backing. Tt pivits exagerate the movement from the ft end much more than a fiver.
- Old coot you know most people don't use their sidewinder setup like you- yours will react much more like a tt than others 5ers.
Old 01-25-2013, 10:31 AM   #15
Oklahoma Proud
MillerTime's Avatar
Sorry, not trying to hijack thread but obviosly op is experiancing what I was stating, since his tv is needing more space now
Old 01-25-2013, 03:09 PM   #16
Rcandvicki's Avatar
4 sheets of 1/2" OSB plywood maybe?
Gives you 16' and you can store easily standing up or laying down.
Just a suggestion.
Rcandvicki is offline   Reply With Quote
Old 02-01-2013, 03:48 PM   #17
BigTJohn's Avatar
I am thinking "stall mats" from Tractor Supply. They are 4x6, can be cut if needed and will store under the trailer once backed into its spot. Easy to move around, somewhat flexible, and last a long time. They are 3/4" thick, if cut properly they make excellent leveling mats for the TT.
Brenda and John
Master Blaster of the Navy
BigTJohn is offline   Reply With Quote
Old 02-01-2013, 03:56 PM   #18
Yeah That's it ...Stall mats. Even though I'm a city kid from New Jersey, I know what those are. Our daughter trained and showed horses in 4H growing up here in MI. and we're only ~ .5 m to a Tractor Supply too!
Thanks BigTJohn
Cathy & Jeff
Midland, Michigan
Old 02-01-2013, 04:04 PM   #19
You might want to take a look at a product called Grass Cells. I have seen them used on golf courses for cart parking areas and adding areas for car parking. The grass grows right up through them and can be mowed and maintained. Grass Cell,Buy Quality Grass Cell from Manufacturers and Suppliers on Alibaba.com
debarymjm is offline   Reply With Quote
Old 02-01-2013, 04:17 PM   #20
I'm going to study that one. Looks like thst may be a more permannt solution.
Thanks debarymjm
Cathy & Jeff
Midland, Michigan
