Old 04-12-2011, 07:09 PM   #1
Moisture build-up on windows.
Any tips on preventing moisture build-up on the interior windows. Have tried the containers that absorb moisture and rice. Opening windows in winter not an option. Thanks
Boggs104 is offline   Reply With Quote
Old 04-12-2011, 07:36 PM   #2
grhodes50's Avatar
Openning the windows or the vents, just a little, is the easiest way I know of. A fan moving the air around will help as well. If that or the containers that asborb moisture doesn't work for you, you might try using a dehumidifier.
Old 04-12-2011, 07:38 PM   #3
AKA Bluebird
dimurrrw's Avatar
Send a message via Yahoo to dimurrrw
Ventilation is the key. If not, then a dehumidifier. Mileage varies.
dimurrrw is offline   Reply With Quote
Old 04-12-2011, 08:27 PM   #4
Too much humidity for sure is the cause of condensation. Try to reduce the humidity by not boil water on the cooktop. If you have a fantastic fan unit use it. It will ciculate the air in your trailer by reducing the condensation. Depending on the outside weather it can be very difficult to deal with condensation. We camped a lot in late fall long time ago and it was a challenge to deal with this problem. You cannot hold your respiration but just this alone is a factor that cause humidity in the trailer during cold weather camping
capucine is offline   Reply With Quote
