Old 07-24-2017, 06:35 PM   #1
Mounting ems to exterior wall
Need to mount our EMS on the exterior wall of our minilite. We have laminated walls so DH is weary about screwing into them. Need some backup from my fellow FR homies.
Is it ok to do this or no?
HoundsAbounds is offline   Reply With Quote
Old 07-24-2017, 06:49 PM   #2
crunchman12001's Avatar
Yes.
I own a different model but the same thin walls.
Use short screws, 1" is fine.
2015 F-250 FX4
Old 07-24-2017, 09:39 PM   #3
Gorilla tape
Dp26 is offline   Reply With Quote
Old 07-25-2017, 06:13 PM   #4
Originally Posted by crunchman12001 View Post
Yes.
Is that an exterior wall?
Old 07-25-2017, 06:42 PM   #5
yes... the interior of an exterior wall. (in a cabinet)
I believe my wall is 2" thick. Look at your entry door opening. This is how thick your walls are.
The interior wall board is only an 1/8" thick so as long as your screw length goes through the EMS and an extra 1/8" for the wall board, you are good.
I used 1" screws.
EDIT: just make sure if you cut the umbilical where it comes through the wall, you do not screw into it.
2015 F-250 FX4
Old 07-25-2017, 06:49 PM   #6
Glad to get some backup. Thank you!!
Old 07-25-2017, 06:58 PM   #7
You are welcome.
You can also secure to a board 1" x 6" and secure board to floor.
You can also secure to same board and suspend to framing of drawer, cupboard ect.
All you are trying to do it keep it off floor (water leaks) and from bouncing around.
A PI EMS can be mounted in ANY position. (flat, sideways, standing up, upside down ect.)
I suggest you get the remote readout display if you have not purchased it with your hard wired unit.
ID:	146048   Click image for larger version
ID:	146049   Click image for larger version
2015 F-250 FX4
Old 07-26-2017, 04:56 PM   #8
Is it waterproof, approved for exterior mounting? I would be particularly concerned with the cable clamps.
Cedar Creek Lake, Texas
2019 Keystone Loredo 290SRL
Andersen hitch
CedarCreekWoody is offline   Reply With Quote
Old 07-26-2017, 05:02 PM   #9
I took it as the interior of an exterior wall.
2015 F-250 FX4
Old 07-26-2017, 06:28 PM   #10
OK, thanks. I thought it looked like yours was on the exterior of the trailer. Sorry for the confusion.
Andersen hitch
Old 07-26-2017, 06:36 PM   #11
No problem, I mounted mine in the cabinet under my entertainment center. (interior of exterior wall)
2015 F-250 FX4
Old 07-26-2017, 07:37 PM   #12
That is what I ment. We are mounying it under the linen cabinet in the bathroom. Want it off the floor just in case.
I am so glad we got the display model! Husband dis mount the display in the bathroom cabinet ( he disnt want to run wires) I sure wish we would have hung it by where you hung yours. Thanks for the pics too!
Old 07-27-2017, 04:19 AM   #13
You are welcome.
2015 F-250 FX4
exterior, mount
