Old 01-21-2016, 09:30 PM   #1
Mouse control
I was recently told that some people have success keeping the mice away by putting charcoal in a few socks and leaving them around. Apparently the critters think there either is or was a fire and run away.
Does anyone have experience with this trick?
2013 Ford F150 3.5 Ecoboost 4X4
Rockwood Ultralight 2618vs
UltraV is offline   Reply With Quote
Old 01-22-2016, 10:01 AM   #2
Haven't heard of or tried the charcoal. We sprinkle cayenne pepper around possible mouse routes (plumbing and electrical holes) and hang containers of moth balls on plumbing inside cabinets. I'm sure you'll get plenty of other fixes!
2015 Silverado gas ext cab 2500
2014 Flagstaff 8528IKWS
greymedic is offline   Reply With Quote
Old 01-22-2016, 10:14 AM   #3
Besides trying to keep every possible entry sealed, as I'm sure that everyone else does, I scatter a box of moth balls around and under the outside of the camper. I don't like the smell of the moth balls on the inside. Don't know if that works or I've just been lucky but I've not had a problem with mice and I live by a fescue pasture.
When sealing entry holes, don't overlook even the smallest holes. Mice need only a dime size hole to get in.
Steve and Kim
Southern Illinois
2021 Cedar Creek 311RL
2020 F350 SRW Crew Cab
si camper is offline   Reply With Quote
Old 01-22-2016, 10:58 AM   #4
muddyrode's Avatar
We use pepermint oil on cotton balls, pouches of fresh cab and moth balls we put then in solo plastic bowls so the smell does not soak in to anything, in the spring open it up and within a couple of days it is aired out. we have been doing this for the last three yeasr and have had no mice since and we live and store it inthe country
2016 SANDPIPER 35ROK
2013 Silverado Duramax 3500HD DRW LB
Stop worrying about the potholes in the road and enjoy the journey
muddyrode is offline   Reply With Quote
Old 01-23-2016, 08:15 PM   #5
kldenny's Avatar
We like the peppermint oil smells great. Also shave some Irish spring soap in bowels and set under cabinets. Both smell good and won't stain.
05 Flagstaff 827 FLS pulled by an 01 Ram 2500 Diesel
kldenny is offline   Reply With Quote
Old 01-23-2016, 08:25 PM   #6
Flybob's Avatar
X3 on peppermint oil. Use essential oil of peppermint ( health food store) not cooking peppermint oil. Put cotton balls in an old mug or glass as the oil will damage surfaces. We have used this for 9 yrs with no mice. Also keeps out spiders.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 01-23-2016, 08:41 PM   #7
Professional exterminators use two things...Poison or traps....I think they know more about it that anyone else. These other remedies may seem to work only if there are no mice to eliminate...I don't think I would feel very good about paying an exterminator to throw around some dryer sheets, peppermint whatever, fairy dust or soap....they use what WORKS!!!
2015 Chev Silverado 3500 dually D/A
2016 Cedar Creek 36CK
B&W Patriot 18K, Trail-Aire pinbox,
Level up, dual panes & all that stuff...
GOTTOYS is offline   Reply With Quote
Old 01-23-2016, 08:49 PM   #8
Flybob's Avatar
Please do not use poison, Rat/mouse poison works by causing the animal to bleed to death internally. In the process they leave and search for water. A dying rodent is an easy target for a hawk or an owl which then results in the death of the hawk or owl.
TST Tire Monitors
2 100W solar panels
Old 01-23-2016, 08:52 PM   #9
Kaadk's Avatar
We've used the dryer sheets for the last few winters without any signs of mice, but I don't really know how many mice are around. The storage lot is right next to the airport, so lots of open fields so there's a good chance they're around.
Old 01-24-2016, 06:02 PM   #10
kldenny's Avatar
Use whatever works for you. The oil, sheets and soap are just suggestions that have worked for some of us.
Old 01-24-2016, 06:34 PM   #11
Oaklevel's Avatar
All good ideas but the bottom line is make sure any open food is removed including crumbs behind cushions.
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
Oaklevel is online now   Reply With Quote
Old 01-24-2016, 07:09 PM   #12
AquaMan's Avatar
I think the best way is to prevent the intrusion in the first place. Poison and such is not a solution in my opinion. Who wants the smell of a decaying rodent inside their trailer or coach.
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2019 - 17
Old 01-24-2016, 08:19 PM   #13
Irish spring.
Two Men and a Little Farm: IRISH SPRING SOAP FOR MICE
Stetay is offline   Reply With Quote
