Old 07-08-2014, 07:22 PM   #1
Boss Hoss's Avatar
My new water transfer system
Because I get tired of hauling 5 gallon containers back to the TT-I came up with this idea.It's sort of fashioned off my 4 wheeler lawn sprayer-but sanitary.
26 gal. fresh water tank-12 volt sure flo pump.I have a front frame hitch on my truck with a cargo basket and that's where I'll put this.I'll load it at the camp fresh water site and then deliver and pump it into the fresh tank.
2013 Palomino 30ft. of Pure Bliss at 5400#-and then we have this 14 ft.Sea Eagle that I tote around for my wife and son.Michigan State Parks are The Best !:thumbsup
Boss Hoss is offline   Reply With Quote
Old 07-08-2014, 08:12 PM   #2
DaveSchwartz's Avatar
I don't have such a large portable FW tank - just a 5gal - but I did read a suggestion here about rigging an RV pump to pump it into the RV FW tank inlet. While I'm pretty economical with the shower, my DW is not and our favorite provincial campgrounds only have (at best) an unthreaded communal hydrant that is not always in range of my 100' of FW hose and Water Thief.
I've tried (and mostly always failed) to pour a 5gal into a funnel in the FW inlet but never thought of the pump idea before (naturally dumb, I suppose). I just so happen to have a good used RV water pump because I replaced the 'sick water buffalo' sounding pump in my old TT with a VSD model (the pump in the new 5er is so quiet I don't have to do that again).
I don't mind hauling the 5gal several times but it will now be more satisfying when more of it ends up in the camper than on the ground.
P.S. I have a 35gal tote-along that I put in the TV and pump into with a Flo-jet (some of the dump stations are a long ways away) so I don't overflow the holding tanks.
2015 Rockwood Signature UltraLite 8282WS Platinum, GY Marathon LRD, TST 507RV TPMS
2005 GMC 2500HD CCSB D/A, Curt E16, Prodigy P2, Garmin RV760LMT w/BC-20 b/u cam
Self restraint is for the young. I'm old and want it NOW!
DaveSchwartz is offline   Reply With Quote
Old 07-08-2014, 08:23 PM   #3
Boss Hoss's Avatar
hey Pal
Glad I could help!!
Old 07-08-2014, 08:35 PM   #4
Originally Posted by DaveSchwartz View Post
I've tried (and mostly always failed) to pour a 5gal into a funnel in the FW inlet . . . .
I use a 5.5 gal Reliance Rhino Pak to add fresh water. It has a spout that fits neatly into the water port on my 21 FBRS. It empties in seconds with minimal water loss. If you decide to continue the old fashioned way, you might give it a try.
Amazon.com : Reliance Rhino-Pak Heavy Duty Water Container (Grey, Medium) : Camping Water Storage : Sports & Outdoors
00buck is offline   Reply With Quote
Old 07-09-2014, 09:36 AM   #5
RPAspey's Avatar
How's this setup? I made it as a transfer pump and a backup water pump.
2000 Cherokee 29BH with 6V batteries, LED lights & 400 watts of solar power, flipped axles and raised. 2007 Tundra 5.7L DC-LB with lots of mods. C-co, 8/158th AVN Maint.
RPAspey is offline   Reply With Quote
Old 07-09-2014, 09:37 AM   #6
RPAspey's Avatar
I also use this more often as its quicker.
ID:	57705   Click image for larger version
Old 07-09-2014, 09:41 AM   #7
Why not get an adapter to connect a hose to your outdoor shower. Then use your antifreeze inlet to pump the water from the portable tank through your outdoor shower into the FW tank.
2022 Flagstaff 26RBWS
2014 Ford F150 Ecoboost
65 nights in 2023 including a 2 month trip to the pacific coast.
roanmountaincampers is offline   Reply With Quote
Old 07-09-2014, 12:25 PM   #8
Campingnut's Avatar
I use a cheap 12v transfer pump and I have a 50 gallon water tank in the back of my truck.
Tim and Bev
2013 Cedar Creek 34RLSA gone trying to find my way back, Magnum 2800w inverter, 560w of solar.
2020 F-350
Campingnut is offline   Reply With Quote
Old 07-09-2014, 12:32 PM   #9
Kaadk's Avatar
After a similar experience to Dave's, trying to pour from a collapsible 5 gal to the fresh water fill, I looked through these forums and ended up going with this:
Self-Priming Drill Pump | Princess Auto
I have yet to try it out since I've managed to either make it through the weekend on a single tank or I've had full hookups, but it should do the trick for under $10.
Old 07-09-2014, 05:16 PM   #10
Boss Hoss's Avatar
very nice set up.
Old 07-09-2014, 07:14 PM   #11
Campingnut's Avatar
I see another princess auto shopper, I use this pump, but waited till it was on sale.
12V Marine Utility Pump | Princess Auto
And for our neighbors to our south I know Harbor freight has something very similar.
Tim and Bev
2020 F-350
Old 08-02-2014, 07:47 PM   #12
Siphon
As I've gotten older I've had to had to work smarter instead of harder. When it comes to transferring water to my TT I use 6 gal green water jugs from Walmart. I set the full jug on the top of the side of my TV bed, put one of a water hose in the jug, and the other end in the fresh water inlet of my TT and let siphon/gravity do the rest. I know everyone's setup is different but this works for me.
2009 Rockwood 2701SS
2008 Tundra Crewmax 5.7
bob7794 is offline   Reply With Quote
water
