Old 10-02-2014, 03:26 PM   #1
Need assistance asap
I have a 2015 Silverback. 1st propane refill. Cannot get tanks aligned in compartment. Must be a trick to getting these in and hooked up.
I get the two tanks in but cannot get secure bar in place to set the regulator on top prior to screwing lines into tanks. What am I missing here? Heavy rain and cold heading my way tomorrow!
Got any ideas? Owner manual sucks!
SilverbackMel is offline   Reply With Quote
Old 10-02-2014, 04:44 PM   #2
riznfall's Avatar
Are the tanks too frat apart or too close together? Some more info would help
Tim
Vengeance touring edition 39R12
2012 Ram 3500 DRW
Tim
2012 Dodge Ram 3500 DRW
riznfall is offline   Reply With Quote
Old 10-02-2014, 05:14 PM   #3
Propane tanks
Too close together to get the grooved brace bar in between
Was able to get it temporarily together and the bat door closed.
Brace bar not in position and I need to step back and attack it again tomorrow morning. Can't be going through this each time we need propane. We use our rv all winter off and on. Hopefully this weekend I can check another Cedar Creek rv and see what I am missing!
VERY tight in that propane compartment.
Old 10-02-2014, 05:19 PM   #4
Bay door
Not good at spell check when frustrated 😡
That's bay door, no bats here except in my head! 😜
Old 10-02-2014, 05:22 PM   #5
arpipeliner's Avatar
Name:	ImageUploadedByForest River Forums1412288216.035035.jpg
If yours is like mine 29RE the tanks are too close together. Try twisting or rotating the tanks till u get one tooth to hold on each tank.
Next time I get home or get grinder near me I will align the tanks straight out and mark the bar a grind in notches where it will be easier to change and look right. Just remember my weren't in a notch on one side after getting filled.
arpipeliner is offline   Reply With Quote
Old 10-02-2014, 05:25 PM   #6
wmtire's Avatar
Does the grooved bar have multiple grooves in it, which you are able to use which applicable grooves, depending on how needed?
Is this what you are describing?
2011 Flagstaff 831 RLBSS
Iíve lost my scapegoat.
Old 10-02-2014, 05:37 PM   #7
Twisting tanks
Yours be looking like my setup. Twisted myself into a turmoil. No go!
Will take another haul out and play twister again tomorrow.
Gotta get this easier! I am over 70 and it ain't getting easier hauling these heavy tanks in and out!
Came out; gotta go back in!!
Thanks. Looking for tricks but not finding any, so far!
Come on baaaa beee let's do the twist.
Maybe I should Tweet Chubby Checker;
He can do it.
Old 10-02-2014, 05:41 PM   #8
Kaadk's Avatar
Now, I'm not condoning running around without locking the tanks down, but if it's that tight, are they really going to move anywhere?
The surest way to lose is to play Marco Polo with a ventriloquist.
Old 10-02-2014, 05:43 PM   #9
Too close
Hey, yours has 3 grooves, mine 2! Probably a money saving thing.
My Keystone had 3 grooves for each tank side. Bet that would work a lot easier!
Old 10-02-2014, 05:44 PM   #10
camper1999's Avatar
Originally Posted by arpipeliner View Post
Attachment 63983
X2 you just need to play with it a little. It is not a big deal if you can't get the tank into the groove as long as it is within both handles of the tank and clamped down tight. You will be good
2011 GMC 2500HD Diesel
