Old 10-03-2016, 04:02 PM   #1
rp53's Avatar
need help
i Have a 21FRBS this will be my first winterize with it. i followed the PDI instructions to winterize it. didn't work i drained the hot water tank and made sure the hot water heater bypass is working. I attached a hose to the anitfreeze inlet put 2 gallons of pink stuff in a bucket opened the cold tap on the kitchen sink turned the water pump on and nothing the water pump is working . i know this because i thought i had the tank valve turned the wrong way boy was i surprised when pink stuff started blowing out the city water inlet I need help. i have attached pictures.
also how do i open the low point drains ? i know is sound like a newbie but on my last TT winterizing was very simple apparently this one is not
2017 Micro Lite 21FBRS
2015 Chevy Silverado dual cab Z71
rp53 is offline   Reply With Quote
Old 10-03-2016, 04:24 PM   #2
clr
From your pictures it looks like the valves are in the correct positions. The antifreeze hose must be below the surface of the antifreeze in the bucket at all times. The pump must be able to prime by drawing a suction and then drawing the antifreeze up and thru the pump. If this does not work try pouring some antifreeze directly into the antifreeze pick up hose and then putting the hose below the surface of the antifreeze. Once primed the pump should be able to draw the antifreeze from your bucket and into the lines of the RV. On the low point drains just unscrew the black caps on the ends of the pipes.
Chuck & Sandra
Engineer/Teacher
2010 F350 CC 6.4
2015 Prime Time Sanibel 3601
clr is offline   Reply With Quote
Old 10-03-2016, 04:45 PM   #3
Life Without Whine's Avatar
have to add this because we own a 21FBRS also ... don't winterize.... move to Florida!
Camping since May 2013 .... FL & GA only so far .... loving it!
Life Without Whine is offline   Reply With Quote
Old 10-03-2016, 05:10 PM   #4
rp53's Avatar
Way to hot in the summer
Old 10-03-2016, 05:13 PM   #5
rp53's Avatar
Thanks clr. will try again when I get home on Friday
as for the low point drain will have to use pliers I can not turn the2
Old 10-04-2016, 11:09 AM   #6
Head Rambler
Stuff blowing out the city water inlet means that the little check valve is stuck open. It's just a rubber flap. You might be able to manipulate it to get it to reseal.
On the low point drains, use two pliers or wrenches. One on the hex part of the fitting and one on the cap. You don't want to spin the fitting if you can help it.
Salem 29RKSS Pushing a 2500 Mega-Cab CTD!
Gotta go campin!
Old 10-04-2016, 11:19 AM   #7
To reseat the check valve in the city water connection, you could also hook up city water and run a gallon or so through the valve.
1988 Coleman Sequoia - popup (1987-2009)
2012 Roo19 - hybid (2012-2015)
2011 Traverse LT, 3.6L, FWD
2009 Silverado Ext Cab, 5.3L, 4x4, 3.73
Old 10-09-2016, 03:14 PM   #8
rp53's Avatar
thanks i needed to reseat the check valve
Old 10-09-2016, 06:16 PM   #9
Head Rambler
Glad you were able to reseat the check valve.
Thanks for letting us know you got it fixed.
Gotta go campin!
