Old 07-08-2010, 12:18 PM   #1
KyDan's Avatar
Need suggestions for battery box strap
I'm looking for ideas for a replacement for my battery
box strap. It's the kind you find at Wally World in the boat
section. The strap is woven poly sort of like the lawn chairs
of old if you remember them. It held for nearly 5 years but
has given up to the rigors of the sun.
I have a bungee cord on there now but bungee doesn't
age well in the elements. I even considered going to
a junk yard and cutting the seat belt out of a scrap car
and sewing myself a new strap. Junk yards are miles away
and so if you have a better idea for a replacement strap,
I'd like to hear it!
Thanks!!
Peace!
Dan & Rita D
Blue Ox WD hitch
Camping days 2010-53, 2011-47, 2012-41, 2013-41, 2014-31, 2015-40, 2016-44, 2017-63, 2018-75, 2019-32
Old 07-08-2010, 12:22 PM   #2
Jan Goldfield
pondlady's Avatar
Have a look at motorcycle strap downs. They look much like seat belts, but not quite as wide. The same straps are used for towing as well and usually have a S hook on both ends. They don't cost much and are long enough to use in pieces for years to come.
pondlady is offline   Reply With Quote
Old 07-08-2010, 12:47 PM   #3
KyDan's Avatar
In the immortal words of Homer Simpson-- "DOH!!" Would you believe
that I HAD 4 cut off ends from my motorcycle ratchet tie downs.
I kept the long cut off ends 4 years until last month when I was
cleaning out my truck in prep for our western states trip.
I tossed them thinking after 4 years if I hadn't needed them, they
were excess baggage.
ARGH!!
EVERY time I toss some gadget or gizmo that I've saved for a rainy day, it RAINS!!
Maybe time for some new ratchet tie downs as mine are getting
kinda tough to release.....
Thanks!
Peace!
Dan & Rita D
Blue Ox WD hitch
Old 07-08-2010, 12:55 PM   #4
Jan Goldfield
pondlady's Avatar
ARGH!!
Thanks!
It's nice to know I am not the only one.....
Old 07-08-2010, 03:19 PM   #5
doctort44's Avatar
After mine wore out, I replaced it with one of those luggage straps from Walmart... the ones with the plastic snap-together catches... the ones you wrap around your suitcase if you're afraid it will pop open..
Terry and Joan and our empty nest
2008 Silverado Crew Cab 5.3liter 3.73
"The Cottage" (2010 Surveyor Sport 189)
doctort44 is offline   Reply With Quote
Old 07-08-2010, 03:57 PM   #6
I did the same thing. Good Ol Wally World.
2005- WDF27RLSS
2001-Dodge-4/4- souped up Cummins
1953 Willys 4/4
1970 Restored Cushman Trackster
Olratlr is offline   Reply With Quote
Old 07-08-2010, 04:28 PM   #7
KyDan's Avatar
"After mine wore out, I replaced it with one of those luggage straps from Walmart... the ones with the plastic snap-together catches... the ones you wrap around your suitcase if you're afraid it will pop open.. "
Another great idea.
Just talked to my wife. We had discussed tossing the straps but
she saved them!! So if I can rig some sort of belt buckle thing,
I'm set. If that fails, I'll go to Wallyworld and look for a luggage
strap.
I figured others had been down this road so that's why I asked.
Thanks to you all!
Peace!
Dan & Rita D
Blue Ox WD hitch
Old 08-30-2010, 09:07 PM   #8
I use a small ratchet strap, works well and I know it is tight.
smokenpam is offline   Reply With Quote
Old 08-30-2010, 09:10 PM   #9
Replacement comes with hardware in 2 lengths:
Battery Strap 38 - $3.99
Battery Strap 54 - $4.99
Ammortized over a few years - cheap.
turbopuppy is offline   Reply With Quote
Old 08-31-2010, 10:23 AM   #10
..AND - if you have an RV dealer with a relatively good parts/accessory department, you should be able to pick up the straps there. Usually found in section where they sell batteries and battery boxes.
...VTX-AL
VTX Al is offline   Reply With Quote
battery
