Old 05-06-2013, 07:28 AM   #11
Fulltime family RVer
It's not a whole lot difference leaving a load in the truck bed. I took 1,500 pounds of yard waste to the dump 5 days after we loaded it into the truck. My pin weight is about 2,300 so it wasn't as much- but same idea.
ependydad is online now   Reply With Quote
Old 05-06-2013, 07:51 AM   #12
Camper Less Camping
Cajun Po-Boy's Avatar
Originally Posted by slide5r4fun View Post
If it were me, I would set the landing gear down and remove some/most of the weight from the truck. No reason to leave that load on the truck overnight if you don't have to.
X2
2013 Sabre 32RCTS-6 (sold)
Cajun Po-Boy is offline   Reply With Quote
Old 05-06-2013, 07:56 AM   #13
Herk7769's Avatar
Originally Posted by prairiecamper View Post
The other thing you have to consider is the fridge level, if you remain hooked up to the truck?
This is why I run the landing gear down when I am hooked up for a short overnight stay and an early (before quiet hours) launch. Last thing I want is the fridge to stop working due to coolant pooling in the coils.
I also disconnect the umbilical cord from the truck.
ID:	29730   Click image for larger version
Name:	RV evaporative Fridge.jpg
HAM CALLSIGN - KC3FFW
Old 05-11-2013, 10:29 PM   #14
If the campsite is level and we want to get an early start we don't unhook, put down any stabilizers or connect water; just plug in the power.
Sirsea is offline   Reply With Quote
Old 05-11-2013, 10:32 PM   #15
Herk7769's Avatar
My camper is not level when we are connected to the truck on a level surface; it is slightly nose down.
Old 05-11-2013, 11:12 PM   #16
I think I'm the same, though I haven't measured to confirm. But- when we overnighted for an easy getaway the next day, we did drop the landing gear and between the squat in the truck and play in the hitch, we were able to level front to back and stay hitched. Saved us a little time in the morning.
Old 05-11-2013, 11:16 PM   #17
Denver, CO
garbonz's Avatar
I thought that absolutely level was not needed in the current generation refers.
2017 Fuse 23T
Old 05-12-2013, 12:02 AM   #18
I know I don't worry about it- but I've been wrong before. :-)
Old 05-12-2013, 09:04 AM   #19
To be level without unhitching I have placed boards, underneath truck tires to correct for nose down, underneath trailer tires for nose high, and under one side or the other for side to side! After leveling stabs down to minimize rocking. I kept telling my brother he needed to be more level, didn't believe me until fridge had to be replaced, older trailer, quite expensive!
Of all the things I've lost in my life the thing I miss the most is my mind!
prairiecamper is offline   Reply With Quote
Old 05-12-2013, 09:34 AM   #20
Oaklevel's Avatar
Level seems to still be very important as we have a friend that their frig stopped working sitting "on" & not level.........
Just remember if you put the landing gear down to put it up before leaving...... If level should be no big deal leaving hooked up.... Shouldn't hurt a 3500 to be left hooked up .....
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
Sadie & Lillie Spoiled Rotten Boxers
